revlution4 Posted September 10, 2018 Share Posted September 10, 2018 Thanks in advance for any advice or help! I am designing a home with a walkout basement and have that almost complete. I added the garage which comes off the main floor but there is no foundation. Its as if the garage is attached to the house but "floating" because there is no floor. Where did I make a mistake? should I have built the garage before making the lower level of the house? I'm using Home Designer Suite 2019. Link to comment Share on other sites More sharing options...
solver Posted September 10, 2018 Share Posted September 10, 2018 Do you have Auto Rebuild Foundation checked? Link to comment Share on other sites More sharing options...
revlution4 Posted September 10, 2018 Author Share Posted September 10, 2018 Thank you for the signature add on. Yes I have auto rebuild foundation checked and monolithic slab. Link to comment Share on other sites More sharing options...
solver Posted September 10, 2018 Share Posted September 10, 2018 Attach the plan file and I'll take a look. Close Suite first. Link to comment Share on other sites More sharing options...
LawB10 Posted September 10, 2018 Share Posted September 10, 2018 Uncheck monolithic slab, and check Walls with footings, change the wall height from 371/2 to the height you want it be. Link to comment Share on other sites More sharing options...
revlution4 Posted September 10, 2018 Author Share Posted September 10, 2018 I'm at 75 mb for the plan size and can't get it to attach. So I compressed the .plan file and it only drops to 26.3 KB, close, I guess I'll have to get rid of a couple things and try again. Link to comment Share on other sites More sharing options...
revlution4 Posted September 10, 2018 Author Share Posted September 10, 2018 Maybe I got it, let me know and thanks for your time looking at it. Evenson P1ex1.zip Link to comment Share on other sites More sharing options...
solver Posted September 10, 2018 Share Posted September 10, 2018 And give the garage a room type of Garage. Link to comment Share on other sites More sharing options...
solver Posted September 10, 2018 Share Posted September 10, 2018 Link to comment Share on other sites More sharing options...
revlution4 Posted September 10, 2018 Author Share Posted September 10, 2018 I don't have that option unfortunately, I attached a screenshot of what is under "Structure" for the Garage. Am I in the wrong menu? Thanks Link to comment Share on other sites More sharing options...
solver Posted September 10, 2018 Share Posted September 10, 2018 I downloaded the Suite trial and took a look. Many times when something unexpected happens -- like no slab under the garage, I'll draw in a new plan, a simple structure duplicating the problem plan. I tried that, and the garage slab generated automatically. I don't know why there is a problem with your plan. You might send this to support -- maybe they have an idea. You might try using Edit Area to copy the 1st and 2nd floors into a new plan. Build a blank 2nd floor, and then copy and Paste/Hold Position. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 10, 2018 Share Posted September 10, 2018 Here are some solutions, at least visually to "solve" software shortfalls in the meantime while Tech Support comes up with advice: DJP Link to comment Share on other sites More sharing options...
Jo_Ann Posted September 10, 2018 Share Posted September 10, 2018 I've encountered this problem before, and I think it's a software bug. It might sound goofy, but try this: Open the room dialog, and under the structure tab, look at the floor structure (L). It is showing as 12 5/8". Go back to the general tab, and specify it as a deck (you left it as unspecified). On the structure tab, the floor structure (L) should change to 8 3/8". Go back to the room type drop-down, and re-specify it as a garage. The structure tab should now show floor structure (L) as 4". Check to see if you now have a slab. 1 Link to comment Share on other sites More sharing options...
revlution4 Posted September 10, 2018 Author Share Posted September 10, 2018 Thank you Jo_Ann !! That worked, I thought I was going to have to spend some money and upgrade my program! Thanks to all of you for your help its nice to be able to reach out! Link to comment Share on other sites More sharing options...
