ICONDEV Posted February 3, 2020 Share Posted February 3, 2020 Will HD ARCHITECT 2018 allow me to draw this cabin in the picture? If so, could someone direct me to a tutorial on how to separate the 3 opposing shed roofs? Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 3, 2020 Share Posted February 3, 2020 The software does not "draw" anything, rather it is your skill and competence that will "draw" anything. There is nothing in that photo that Architectural is unable to draw, the only limitation is you and your persistence. DJP Link to comment Share on other sites More sharing options...
solver Posted February 3, 2020 Share Posted February 3, 2020 Have you tried? I know of no tutorial. Link to comment Share on other sites More sharing options...
ICONDEV Posted February 3, 2020 Author Share Posted February 3, 2020 Yes, and i cannot get the roof correct. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 3, 2020 Share Posted February 3, 2020 You define 3 shed roofs in the walls that support those shed roofs and then keep building roofs making indicated changes until you get what you are after. If that does not work and you have tried everything you can reach, then upgrade to Home Designer Pro where, roof-wise anything is then possible once you learn how to use the new manual roof tools. DJP 1 Link to comment Share on other sites More sharing options...
ICONDEV Posted February 3, 2020 Author Share Posted February 3, 2020 it seems as though I need to break them up and treat them as 3 independent rooms/roofs? Link to comment Share on other sites More sharing options...
solver Posted February 3, 2020 Share Posted February 3, 2020 On 2/3/2020 at 6:03 PM, ICONDEV said: 3 independent rooms/roofs? Expand Roofs build over rooms. Getting the basic form is easy -- getting the roof correct will be far more difficult. You really need the manual roof tools in Pro to do this type of roof. Link to comment Share on other sites More sharing options...
ICONDEV Posted February 3, 2020 Author Share Posted February 3, 2020 Would using a wall break, or potentially turning the interior walls to reformatted exterior walls help me? Link to comment Share on other sites More sharing options...
solver Posted February 3, 2020 Share Posted February 3, 2020 On 2/3/2020 at 7:07 PM, ICONDEV said: using a wall break Expand You will need to break some walls. On 2/3/2020 at 7:07 PM, ICONDEV said: turning the interior walls to reformatted exterior walls Expand Makes no difference. -------- Here is what happens. Note the incomplete roof overhangs. Walls could be easily drawn in. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 3, 2020 Share Posted February 3, 2020 On 2/3/2020 at 6:03 PM, ICONDEV said: it seems as though I need to break them up and treat them as 3 independent rooms/roofs? Expand Exactly correct, keep at it, please! DJP Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 3, 2020 Share Posted February 3, 2020 1 1 Link to comment Share on other sites More sharing options...
ICONDEV Posted February 3, 2020 Author Share Posted February 3, 2020 I'm getting closer! 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 4, 2020 Share Posted February 4, 2020 Great! now as earlier suggested, add, manually your missing "Attic Walls" (you go to the "Attic <A> " level, turn on the "Reference Display" and then manually draw your walls that are missing on that level, place your windows and doors and VOILA! You have it all, and well done! DJP 1 Link to comment Share on other sites More sharing options...
LawB10 Posted February 4, 2020 Share Posted February 4, 2020 Here's a modified version.... forest 1.planFetching info... 1 1 Link to comment Share on other sites More sharing options...
ICONDEV Posted February 5, 2020 Author Share Posted February 5, 2020 On 2/4/2020 at 11:49 PM, LawB10 said: Here's a modified version.... forest 1.planFetching info... Expand You nailed it! THANK YOU SO MUCH! Link to comment Share on other sites More sharing options...
ICONDEV Posted February 6, 2020 Author Share Posted February 6, 2020 On 2/4/2020 at 1:02 AM, DavidJPotter said: Great! now as earlier suggested, add, manually your missing "Attic Walls" (you go to the "Attic <A> " level, turn on the "Reference Display" and then manually draw your walls that are missing on that level, place your windows and doors and VOILA! You have it all, and well done! DJP Expand I went to the Attic level and manually drew the walls, but they did not extend up into the attic. It's as if they drew the L2 walls, despite me not even having a L2. Suggestions sir? Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 6, 2020 Share Posted February 6, 2020 On 2/6/2020 at 4:36 PM, ICONDEV said: Suggestions sir? Expand Attic walls (to be identified as such by the software) also need to be marked, by you manually as ""Attic Walls", "No Locate" and "No Room Define". When that is done, by you, they should then filll up the side-spaces you wish them to. Those check-boxes are to be found on each wall's "Wall Specification Dialog - General Tab", take a look please! DJP Link to comment Share on other sites More sharing options...
ICONDEV Posted February 7, 2020 Author Share Posted February 7, 2020 I selected the two check boxes, but it did not fill in. Where else may I have messed up? Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 7, 2020 Share Posted February 7, 2020 The exterior of this design is fairly easy to do, BUT...the interior could be a problem (depending on what you want). And, you haven't provided enough info for your intentions on the interior. This is much more complicated to do with Architectural, as opposed to Pro. Posting your plan might help. Link to comment Share on other sites More sharing options...
ICONDEV Posted February 7, 2020 Author Share Posted February 7, 2020 All 1 level, all vaulted ceilings. I'm trying to get the attic walls to fill in and the roofs to overhang on the insides to match the outsides. Thanks in advance! On 2/7/2020 at 5:21 PM, Jo_Ann said: The exterior of this design is fairly easy to do, BUT...the interior could be a problem (depending on what you want). And, you haven't provided enough info for your intentions on the interior. This is much more complicated to do with Architectural, as opposed to Pro. Posting your plan might help. Expand Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 7, 2020 Share Posted February 7, 2020 And therein presents the big elephant in the room, "all vaulted ceilings". When I said post the plan, I meant the plan FILE. Not images. Before posting the plan file, try to make the structure as complete as possible. Roof pitch and basic ceiling heights are important. If you intend to add the porch, then you need to do that also before posting the plan. Close your HDA program before uploading the plan. 1 Link to comment Share on other sites More sharing options...
