pacs1963 Posted November 20, 2014 Share Posted November 20, 2014 I'm using Home Designer Suite 2012 (I'm a rookie at this software) and would like to know how to put a butterfly roof on a contemporary style home such as the one in the attached photo. Any help is much appreciated, Thank you! Phil Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 20, 2014 Share Posted November 20, 2014 How to do all basic roof styles is explained in the software within the "Build Roof" dialog "Roof Styles" tab with pictures and text how to preset the software for a particular outcome or result. Your roof type is called a "shed roof" in that information. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted November 21, 2014 Share Posted November 21, 2014 Should be do able using TWO shed Roofs back to back , so the two following KB Articles should help you in the right direction ,except you will need too reverse the pitch as the low point is in the middle of the Roof where the ridge normally is. http://www.homedesignersoftware.com/support/article/KB-01020/52/Home-Designer/Roofs/Creating-Multiple-Shed-Roofs.html http://www.homedesignersoftware.com/support/article/KB-00492/52/Home-Designer/Roofs/Building-a-Clerestory-Roof.html give it a try and post back with Pictures or post the plan so someone can give you more help. Mick Link to comment Share on other sites More sharing options...
pacs1963 Posted November 21, 2014 Author Share Posted November 21, 2014 Thanks much for the help. I will post results! Link to comment Share on other sites More sharing options...
katalyst777 Posted November 24, 2014 Share Posted November 24, 2014 The old forum has some information on this "butterfly" style of roof.http://hometalk.homedesignersoftware.com/showthread.php?16122-Butterfly-Roof-How-to-build-in-Home-Designer-Pro-v8&highlight=butterflyFrom the old forum, since I'm not sure how much longer it will be "live."The only way I could get close with the automatic tools in Architectural was to create two separate structures each defined with their own Shed roofs and then move them in close enough for the roof plane edges to touch, turn off Auto Rebuild Roofs, and then get rid of the extra walls separating in to two structures.However, with your Pro, it should be relatively easy for you to manually create the roof, rather than use the automatic tools. Link to comment Share on other sites More sharing options...
MCMTim Posted August 12, 2016 Share Posted August 12, 2016 I'm a bit late to this thread but I just started using Home designer suite 2017. I am also trying the create a butterfly roof. The problem solvers input from 2014 was not at all helpful. A butterfly roof is not a "shed roof" and I have found no way to create a "shed roof" that slopes downward from both ends with the low point in the center of the structure. I'll try the training videos and other resources but I'm not optimistic that I'll find anything on point. Ha anybody found a way to build one of these style roofs? Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 12, 2016 Share Posted August 12, 2016 You didn't read either article closely enough. They both have the answer, and it IS a 'shed' roof...more specifically a 'high shed' roof (and it says so in the knowledge base article). The trick is to create a skinny room in the center of the structure, and specify 'no roof' over the room. Link to comment Share on other sites More sharing options...
LawB10 Posted August 13, 2016 Share Posted August 13, 2016 Like Jo Ann said you create a room in the center for separation, then you gable the side the walls, click the front wall, open it specification box and click high shed/gable wall. Use the break wall tool for the center room, and uncheck full gable wall. Link to comment Share on other sites More sharing options...
LawB10 Posted August 13, 2016 Share Posted August 13, 2016 Here's what it should look like when your done. Once you have the roof to your liking, turn off auto rebuild roofs and delete the center walls. butterfly.plan Link to comment Share on other sites More sharing options...
GroverJR Posted July 8, 2017 Share Posted July 8, 2017 So, I have made my sample butterfly roof, but I wonder if it is possible to have different roof slopes. In this example, I would like the shorter section to have a 10 slope, and the larger section will have a slope of 4. I've posted the plan. Any thoughts? butterfly_example.plan Link to comment Share on other sites More sharing options...
