ChiefUserJenni47 Posted April 26, 2017 Share Posted April 26, 2017 I have been using Home Designer Pro for a little less than a month. Experience with SketchUp Pro (4 months) and Autodesk MAYA (5 years). I am trying to create a porch on the front of my house. I have constructed my walls based on the CAD given to me. Some of the interior walls seem to be impacting the exterior walls and roofs in a way that is making it impossible to create the porch roof the way that I want. I am wondering what I am doing wrong and if anyone has any suggestions for me. https://www.homedesignersoftware.com/videos/watch/10138/home-designer-quick-start.html?playlist=200 is the tutorial I was using to attempt to create the Porch (1:01:35 mark). When I attempt to create the porch this way it creates some very strange geometry for me on the second floor. The main issue is in the right corner of the would be porch. Please help! Thank you! Link to comment Share on other sites More sharing options...
LawB10 Posted April 26, 2017 Share Posted April 26, 2017 Could you post the plan please? Link to comment Share on other sites More sharing options...
Jo_Ann Posted April 26, 2017 Share Posted April 26, 2017 ??? You haven't said what the problem is. Post an image of what is happening. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 27, 2017 Share Posted April 27, 2017 The listed tutorial you referenced is for Home Designer Pro, is that what YOU have? DJP Link to comment Share on other sites More sharing options...
ChiefUserJenni47 Posted April 27, 2017 Author Share Posted April 27, 2017 Thank you for all of your responses! I am using Home Designer Professional 2018. Attached are images of me attempting to build the porch. The first image shows what happens when I create a deck with straight deck railing and then convert into porch. It creates a very strange roof like structure will walls that I don't want. I also don't want the railing, I want columns, but when I turn the railing off it turns them into walls. Again this was all based on the tutorial I was watching. Then I manually create my own roof and I still have issues with the corner right corner. I think it has something to do with the interior and exterior walls creating an empty space? I also unsure how to manually create a gable roof on the part of the roof over the door. I tried the break wall tool, but that did work, and I also tried the Gable/Roof Line. Thanks again for all of your suggestions and help. Link to comment Share on other sites More sharing options...
solver Posted April 27, 2017 Share Posted April 27, 2017 Delete what you have. Draw 3 Room Divider walls to form the porch. Set the Room Type to Porch. If the problem wall is positioned correctly, you may need to manually shape it in elevation. Link to comment Share on other sites More sharing options...
