Fidellaty Posted May 29, 2016 Share Posted May 29, 2016 When I add materials shouldn't they be saved in the User Library file? I've added several items and they come up missing. I've found out not to try to see what's in the User Library file.... Link to comment Share on other sites More sharing options...
solver Posted May 29, 2016 Share Posted May 29, 2016 How did you add the materials? Link to comment Share on other sites More sharing options...
Fidellaty Posted May 29, 2016 Author Share Posted May 29, 2016 Should it matter? Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 29, 2016 Share Posted May 29, 2016 It makes the difference between success and failure, only one method works, all other methods fail, so yeah, it matters a lot. What did you actually do? DJP Link to comment Share on other sites More sharing options...
Fidellaty Posted May 29, 2016 Author Share Posted May 29, 2016 Go to User Catalog, right click, New, Material. Usually... I suppose the missing ones I imported and then deleted the original file. Assuming if they showed up in the library browser, they'd be saved? So CA decided to allow different options to add materials, but only one method saves to the User Library? Interesting. Link to comment Share on other sites More sharing options...
LawB10 Posted May 29, 2016 Share Posted May 29, 2016 That's to add new Material like it says, you added a catalog file as a material. click Library>import, click on the file, the software will automatically install it. Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 30, 2016 Share Posted May 30, 2016 If you are using a custom texture you MUST save it to a known location on your hard drive and then do not ever move or rename it, if you do the material will loose its connection to the texture file which is probably what happened. DJP 1 Link to comment Share on other sites More sharing options...
LawB10 Posted May 30, 2016 Share Posted May 30, 2016 David your right, but take a look at the size of the file. It's 2.63GB that's a catalog. Link to comment Share on other sites More sharing options...
Fidellaty Posted May 30, 2016 Author Share Posted May 30, 2016 Thanks for the info. I have moved some folders. I believe I have them set up now, so I won't need to move again. (I put them in a sync location.) I just did a test and that must have been what happened. The 2.63GB must be the items I got from the 3D Warehouse and in the beginning I didn't think much about adding large files. Since I am unable to see what is in that folder, I have no way to weed out the large ones. Maybe I should start over? Does anybody know how to see what's in that folder? Link to comment Share on other sites More sharing options...
katalyst777 Posted May 31, 2016 Share Posted May 31, 2016 Does anybody know how to see what's in that folder? Looks like you've turned off your preview panes. KB-00723: Displaying 2D and 3D Views in the Library Browser Link to comment Share on other sites More sharing options...
