New_Bee Posted January 8, 2016 Share Posted January 8, 2016 I have a plan, for the most part like I want it. But, I want to raise it on 16 - 30cm x 30cm (~ 12" x 12") pillars, one story up. I want to have a lower level to use for storage, parking, etc. (Not sure if that is even the proper size. But, I figure more is better / stronger.) The home will be constructed where no utilities are located. So, I will also put three large tanks (20,000 liters each) under the home, for our water requirements. I live in Cambodia, so anything concerning "code" does not apply here. Believe me, it really does not apply here! house.plan I have looked in the Database, to no avail. So, any instruction on how to do this would be appreciated. ======================= 2nd question: I am assuming the roof is generated by a default setting? If not, how can I change it to metal, with metal frame for the roof, rather than lumber and, what I can only assume is shingles? Again, any instruction on how to sort this would be appreciated. Thanks again, Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 8, 2016 Share Posted January 8, 2016 Go back to the Knowledge Database and type 'house on piers' in the search bar. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 8, 2016 Share Posted January 8, 2016 Here is my take on You Tube: https://youtu.be/VL8CU5miRuo DJP 1 Link to comment Share on other sites More sharing options...
solver Posted January 8, 2016 Share Posted January 8, 2016 Insert a new floor under the house. Use one of the available tools -- Soffit, Slab, Closed Shape from library to create the columns. You can set the roof materials, I think, in your roof defaults. Not sure about the metal framing. I believe you would need Pro for that. 1 Link to comment Share on other sites More sharing options...
LawB10 Posted January 8, 2016 Share Posted January 8, 2016 Is this is what you want to do? house 1.plan 1 Link to comment Share on other sites More sharing options...
New_Bee Posted January 8, 2016 Author Share Posted January 8, 2016 Is this is what you want to do? house.jpg house 1.plan Yeah, pretty much. 1 floor downstairs, for storage, parking, rainwater harvesting tanks, solar battery and power house, etc. I will load the file now, to see. Thank you. Link to comment Share on other sites More sharing options...
