Tyler2022 Posted January 16, 2023 Share Posted January 16, 2023 hey so I am trying to get my outside wall application setup and I seem to be stuck because I cannot find moisture barrier would that be the lath or the house wrap? can anyone help me on what i should use as my vapor barrier Link to comment Share on other sites More sharing options...
Rookie65 Posted January 16, 2023 Share Posted January 16, 2023 house wrap Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 16, 2023 Share Posted January 16, 2023 You will have to upgrade to HD Pro in order to create custom wall types, sorry. Your "signature" shows that you use "Architectural 2021", if that is out of date, please update it so it shows what you are now using, please. DJP Link to comment Share on other sites More sharing options...
Tyler2022 Posted January 16, 2023 Author Share Posted January 16, 2023 2 hours ago, DavidJPotter said: You will have to upgrade to HD Pro in order to create custom wall types, sorry. Your "signature" shows that you use "Architectural 2021", if that is out of date, please update it so it shows what you are now using, please. DJP I'm not using 23 because of the current situation that I'm in. Link to comment Share on other sites More sharing options...
Tyler2022 Posted January 16, 2023 Author Share Posted January 16, 2023 what are you talking about? i have the ability to add some things to walls i was looking for a quick recommendation Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 16, 2023 Share Posted January 16, 2023 4 minutes ago, Tyler2022 said: 2 hours ago, DavidJPotter said: You will have to upgrade to HD Pro in order to create custom wall types, sorry. Your "signature" shows that you use "Architectural 2021", if that is out of date, please update it so it shows what you are now using, please. DJP I'm not using 23 because of the current situation that I'm in Do you or don't you have Pro? If you have Architectural it offers NO customizing of wall types. DJP Link to comment Share on other sites More sharing options...
Tyler2022 Posted January 16, 2023 Author Share Posted January 16, 2023 look at the picture that i took DJP it allows me to add materials those three items under sand finish cream were me so i am not quite sure what you are saying. Yea my version is basic still but it was all that I can afford Link to comment Share on other sites More sharing options...
Tyler2022 Posted January 16, 2023 Author Share Posted January 16, 2023 I am not quite sure what is going on. I was asking if anyone uses a vaspor barrier under the housewrap because whenever I looked at a detailed example i was asking if there is a substitution within the program i can use for the water barrier Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 16, 2023 Share Posted January 16, 2023 My answer above was based upon me checking using my 2023 Architectural trial version. DJP Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 16, 2023 Share Posted January 16, 2023 Most default wall types have a "House Wrap" AKA vapor barrier", I think only masonry and block walls do not use a "House Wrap". What I was trying to communicate is that Wall layers and definitions can not be manually edited in Architectural 2023, if your version can, then good for you. DJP Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 16, 2023 Share Posted January 16, 2023 I looked again. I stand corrected, thank you Eric. DJP Link to comment Share on other sites More sharing options...
Tyler2022 Posted January 17, 2023 Author Share Posted January 17, 2023 it just that i dont have 23 but i have the same capabilities can we get back to the original question please? Link to comment Share on other sites More sharing options...
Tyler2022 Posted January 17, 2023 Author Share Posted January 17, 2023 5 hours ago, solver said: I was trying to. I was trying to see if there are alternatives that i can use for the barrier because I'm aware that the 22 software doesn't have the right material. So i was asking for suggestions Link to comment Share on other sites More sharing options...
solver Posted January 17, 2023 Share Posted January 17, 2023 On 1/16/2023 at 7:14 AM, Tyler2022 said: so I am trying to get my outside wall application setup and I seem to be stuck because I cannot find moisture barrier would that be the lath or the house wrap? can anyone help me on what i should use as my vapor barrier Is this a construction question? Your wording makes me think you don't understand the components of the wall you are building. However, you may create your own material if one does not exist in the library. But my real question is why add all these layers to your wall? Especially ones that are 0" thick. Link to comment Share on other sites More sharing options...
Tyler2022 Posted January 17, 2023 Author Share Posted January 17, 2023 you are right and I'm totally open on learning the right way of the right components that goes on a outside wall under the stucco or even inside too. if you have some time to teach me i would absolutely appreciate the education. this is the materials that builders use in my area which is new Mexico. Truly to be honest with you i have walked multiple frames that had the lath and the wire in the ongoing process Link to comment Share on other sites More sharing options...
