ChiefUserTom7 Posted August 24, 2022 Share Posted August 24, 2022 I’m using Home Designer Pro 2023. I’m modeling my home and am having trouble trying to figure out how to draw a stairwell with brick stairs leading from my patio on the main level to my basement level. I have a walk out basement/garage. I’ve tried drawing a terrain wall, a retaining wall, a slab, etc. I can’t seem to make it work. The terrain shows through in spots. I’m attaching some pictures that might help. Any suggestions would help. I’ve scoured the training videos on the Chief Architech web site, but can’t seem to find one that instructs me how to do this. The patio and stairwell are on the back side of the house. The house is on a hill with sloping terrain down on all sides. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 24, 2022 Author Share Posted August 24, 2022 Both. Also, I’m not clear about the signature. What’s this about? Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 24, 2022 Share Posted August 24, 2022 In the Knowledge Base search window, type 'egress'. This might get you started on the right track. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 24, 2022 Author Share Posted August 24, 2022 Thanks, This might work. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 24, 2022 Author Share Posted August 24, 2022 Bent Tree X12 CV3practice_auto_save_auto_save_bak.zip Here's the floor plan for the project. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 25, 2022 Author Share Posted August 25, 2022 The Knowledge Base “Egress” method is still tricky. I haven’t been able to figure this out completely. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 27, 2022 Author Share Posted August 27, 2022 Anybody else out there have any suggestions? Link to comment Share on other sites More sharing options...
solver Posted August 27, 2022 Share Posted August 27, 2022 On 8/27/2022 at 8:51 PM, ChiefUserTom7 said: Anybody else out there have any suggestions? Expand The plan you attached has no terrain, and it opened in Pro 2022, not 2023. Are you really using 2023? Did you upload the wrong file -- one without a terrain? Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 28, 2022 Author Share Posted August 28, 2022 I suppose that could have happened. I copied the file and pasted it into Hometalk. Let me check the file again and see if I find the terrain. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 28, 2022 Author Share Posted August 28, 2022 I probably created this file in an earlier version of Home Designer Pro, probably 2021 or 2022. I updated this file in 2023 version, however. This one has the terrain, though I have altered the terrain somewhat on a file on my other computer. This should suffice for the questions I have, however. Any help would be greatly appreciated. By the way, is there a way to request help from a specific member on this forum? Bent Tree X12 CV3practice_auto_save4_auto_save.zipFetching info... Link to comment Share on other sites More sharing options...
Rookie65 Posted August 28, 2022 Share Posted August 28, 2022 You can send someone a direct message 1 Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 28, 2022 Author Share Posted August 28, 2022 I see the file I uploaded has no data. I'm not sure what I have done wrong. I sent the file to ZIP and sent the file in this format, but when I try to extract the computer says there is no data. Any suggestions? Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 28, 2022 Author Share Posted August 28, 2022 How do you send a direct message on this forum? Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 28, 2022 Author Share Posted August 28, 2022 I think this file will work. Hopefully, it can be unzipped. Thanks for your patience.Untitled 1.zip Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 28, 2022 Share Posted August 28, 2022 Why does your file label say x12, and how do you have 'mulled' windows? 1 Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 28, 2022 Author Share Posted August 28, 2022 I had a guy help with the plan a few years ago and he used Chief Architect to do some of the drawings. The mulled windows are large fixed windows. I like what you have done in the picture. Can you show me how you did this? Also, there's a landing at the bottom of the stairs and one step down further to the stairwell. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 28, 2022 Author Share Posted August 28, 2022 Jo_Ann, I guess what I am asking is what method you used to form the stairwell? Did you use foundation walls, polyline solids or slabs possibly? Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 28, 2022 Share Posted August 28, 2022 I followed the directions for the egress window, as I suggested that you try. Of course it became more of an egress 'room', because of it's size. Link to comment Share on other sites More sharing options...
ChiefUserTom7 Posted August 29, 2022 Author Share Posted August 29, 2022 Would it be possible for you to post the file that you used to make this drawing? Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 31, 2022 Share Posted August 31, 2022 You shared your plan earlier while it was actively open in HD Pro, when when done results in an unusable copy of the plan file. Close Pro and THEN upload a copy of your file, only that way will others then be able to view and edit (help you) the file. I finally found your good copy, thank you. DJP Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 31, 2022 Share Posted August 31, 2022 DJP Bent Tree X12 CV3practice_auto_save4_auto_save.zipFetching info... Link to comment Share on other sites More sharing options...
