cooldood Posted November 12, 2021 Share Posted November 12, 2021 I am a noob so please forgive my noobiness :) I am trying to raise the roof height but keep getting the same error. any suggestions? I would like mine to at least resemble the blue one. LOL Home Designer Arch. 2022 Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 12, 2021 Share Posted November 12, 2021 The roof pitches are steeper in the photo than in your posted image. Go to the "Build Roof" dialog and change the pitch (angle) of the roof steeper to better match your photo. DJP Link to comment Share on other sites More sharing options...
cooldood Posted November 12, 2021 Author Share Posted November 12, 2021 You sir are correct. According to the print there are two different roof pitches, 8/12 and 12/12. I set the two wider walls to 8:12 When I try to change the two narrower sections to 12:12 I get the error. I am doing it in 3D view by clicking on the gable wall and changing pitch. Link to comment Share on other sites More sharing options...
Rookie65 Posted November 12, 2021 Share Posted November 12, 2021 With Architectural, you don't have manual roofs. Upgrade to Pro and you can eliminate that problem with having 2 different pitches Link to comment Share on other sites More sharing options...
cooldood Posted November 12, 2021 Author Share Posted November 12, 2021 Seems hard to believe changing roof pitches is an "upgrade". $300 to change a roof pitch is just short of stealing Link to comment Share on other sites More sharing options...
Rookie65 Posted November 12, 2021 Share Posted November 12, 2021 You get a lot more than just that. Compare the 2 programs Link to comment Share on other sites More sharing options...
cooldood Posted November 12, 2021 Author Share Posted November 12, 2021 9 minutes ago, Rookie65 said: You get a lot more than just that. Compare the 2 programs No doubt, but come on, a simple gable roof default is not an option? Gable roofs are incredibly common and simple to design. It is an abject software design failure by design. I am not here to start an internet war. I realize I have been dooped and now I am moving on. Thanks for time everyone Link to comment Share on other sites More sharing options...
solver Posted November 12, 2021 Share Posted November 12, 2021 58 minutes ago, cooldood said: When I try to change the two narrower sections to 12:12 I get the error. I am doing it in 3D view by clicking on the gable wall and changing pitch. You just need to review the documentation on how to control pitch. 2 hours ago, cooldood said: I am trying to raise the roof height What are you trying to raise -- the entire roof? Link to comment Share on other sites More sharing options...
cooldood Posted November 13, 2021 Author Share Posted November 13, 2021 20 minutes ago, solver said: You just need to review the documentation on how to control pitch. What are you trying to raise -- the entire roof? This obviously was not "solving" so Was this meant to be spiteful? Or is it just your nature to be obtuse? Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 13, 2021 Share Posted November 13, 2021 16 minutes ago, cooldood said: This obviously was not "solving" so Was this meant to be spiteful? No, it was factual, useful advice, where you wish to set pitches other than the default pitch set in the "Build Roof Dialog" you set those diverging pitches by way of the "Wall specification dialog - roof tab -roof pitch input box" to guide the auto-roof generator to a desired result. If you are not obtaining a desired result then one must find where they have erred in manually setting up for the auto-roof generator (Build Roof Dialog - Roof Styles tab" is an excellent source of true data relative to setting up for various differing roof types and geometry). DJP Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 13, 2021 Share Posted November 13, 2021 You can NOT change a roof pitch by opening a gable wall, and setting the pitch. You change the pitch on the eave walls on either side of the gable. Link to comment Share on other sites More sharing options...
madisonv Posted November 16, 2021 Share Posted November 16, 2021 I wish I could do that lol. Your work seems fine for me Link to comment Share on other sites More sharing options...
rocketseeds Posted November 16, 2021 Share Posted November 16, 2021 That looks fine for me:) Link to comment Share on other sites More sharing options...
