Will Home Designer Pro work for my needs?
waitinis71
Hi all,
I am an avid do-it-yourselfer and find myself more and more doing renovation jobs for friends and family...this is not a business, but I find myself wishing I had a program that would help me not only design additions, decks, etc. but visualize them for the people I am doing this for so they have a good idea of what it might look like.  More often than not, I am either adding to an existing building or modifying it somehow, both interior and exterior.  Up here in Maine we use a lot of monolithic slabs or posts below frost level.  The Pro version seems to have a lot more features that allow you to manually adjust framing and other aspects of the building but is it much better than the Architect version?  I don't want to buy a version that will frustrate me when I go to change something only to find out there are no options for that.  Is the Pro version in your experiences, robust enough to be as flexible as I need?  Any advice would be greatly appreciated.
I gather you live is USA. PRO IS PROBABLY BETTER THAN THE OTHER VERSIONS. Since you mainly use slabs.....I would suggest you download the free copy and use it for the entire month before buying it. However you will not be able to save nor print during that month.
I agree with Robyn. Chief has trial versions for all the products, and an easy upgrade path to the more expensive titles.
I chose Pro over the other Home Designer options because it does what I need and the others did not. I also considered Chief Premier, but could not justify the cost difference.
  • 2 weeks later...
