How to define walls?
jimscelz
I'm trying to set the default siding of my exterior walls but cannot find where the wall defaults settings are located.  The help file shows a 'define' button under edit/default settings/wall but I don't have that button.  How do I set wall defaults?
Here's what you have to do in Suite.
You draw the wall, open it's specification box , click materials>exterior wall and change the material.
In the thickness box change the thickness to what you want.
Then go to Edit>default settings>walls, open the exterior wall and select the wall you created. That will be you're default wall
for the plan.
