Sign in to follow this
ChiefuserLarkin
stairs/door display
You really should have a landing there.   But despite that, there is no option to 'move to the front of group' for doors.  It would just be easier to draw in the door swing with cad lines, to represent the door.
OR...
You could draw in an independent  room, using the railing wall (make it an 'unspecified' room type),  to represent the landing.  Set to the right height, this room will automatically show the door swing.
Still haven't figured out when I build the floor joists it only does them in partial areas.
Start a new thread, and attach the plan file. Someone will solve your problem. No plan = guessing.
Open each and every room dbx on floor 1, and put a check in the default box for floor structure(L).
Some of the rooms are already checked, and those are the rooms already showing the framing.
The next step (of course) is to open the build framing dialog, and put a check in the 'build floor framing' box.
