jeffreybianchi Posted April 21, 2016 Share Posted April 21, 2016 I'm using HD Pro 1015 I'm drawing the as-built for a home remodel. As you can see from the first image, the roof extends down further over the right portion of the house. There's no porch or anything. It's just a lower, deeper overhang than on the rest of the house. Problem is, I can't figure out how to get rid of the gap in the fascia (see second drawing). Any help is always appreciated...thanks. Floor Plan-Perspective Full Overview Image.pdf Floor Plan-Perspective Full Overview Image 2.pdf Link to comment Share on other sites More sharing options...
LawB10 Posted April 21, 2016 Share Posted April 21, 2016 Check your Roof overhang.... Link to comment Share on other sites More sharing options...
jeffreybianchi Posted April 21, 2016 Author Share Posted April 21, 2016 LawB10: Thanks for the response and I don't mean to be dense but I don't understand what you mean. Link to comment Share on other sites More sharing options...
solver Posted April 21, 2016 Share Posted April 21, 2016 . Link to comment Share on other sites More sharing options...
jeffreybianchi Posted April 21, 2016 Author Share Posted April 21, 2016 Thanks Eric, but still lost. I still want to know how to get the soffit of the lower part of the roof all the way to the edge of the house. I'm afraid I don't know what "default to overhang" means. I tried unchecking it, and put a negative value in the box below, and it made the soffit a little wider, but then it stops and there's still a gap. Link to comment Share on other sites More sharing options...
solver Posted April 21, 2016 Share Posted April 21, 2016 You should probably post the plan. Link to comment Share on other sites More sharing options...
jeffreybianchi Posted April 21, 2016 Author Share Posted April 21, 2016 Here you go: Floor Plan.plan Link to comment Share on other sites More sharing options...
jeffreybianchi Posted April 21, 2016 Author Share Posted April 21, 2016 Eric: Not sure if you will have another idea but I was able to achieve the look by simply manually building the fascia with the soffit tool. I'm pretty sure that because I have one continuous roof plane with two different heights and baselines that the program can only accommodate directions for one. Maybe I'm wrong. Floor Plan-Perspective Full Overview Image 3.pdf Link to comment Share on other sites More sharing options...
solver Posted April 21, 2016 Share Posted April 21, 2016 I'm pretty sure that because I have one continuous roof plane with two different heights and baselines that the program can only accommodate directions for one. Maybe I'm wrong. I believe you are correct. I tried this in Chief and it fails in a different way. The box fills in correctly, but then the other side is incorrect. Link to comment Share on other sites More sharing options...
jeffreybianchi Posted April 21, 2016 Author Share Posted April 21, 2016 Eric: Thanks for taking the time to investigate! Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 21, 2016 Share Posted April 21, 2016 Here is a You Tube video of me looking over and editing your plan: https://youtu.be/yDUb1ibz3Pg DJP Floor Plan.plan Link to comment Share on other sites More sharing options...
jeffreybianchi Posted April 21, 2016 Author Share Posted April 21, 2016 David: Thanks for the video...that was great! Link to comment Share on other sites More sharing options...
solver Posted April 21, 2016 Share Posted April 21, 2016 I noticed the odd baselines too, but redrawing the roof still leaves a gap where the roof plane is extended. Link to comment Share on other sites More sharing options...
LawB10 Posted April 22, 2016 Share Posted April 22, 2016 Here's what I came up with using Suite 2016..... One thing I notice was none of the walls are Gabled. Looking at the pics, that's not a 8" pitch I think the end walls should be gabled and then extend the roof down. Link to comment Share on other sites More sharing options...
