cte677 Posted March 14, 2016 Share Posted March 14, 2016 Home Designer Architectural 2016 See attachments. 1) Why the double lines in the roof on the right side?2) It is difficult to move any of the walls in that area. I would like the extension wall to be 9 foot wide ... the angle wall starting 1 foot from the end.3) The two angle walls to be 45 degrees. Would Pro fix all of these problems? House Bismarck South 160314 15 no interior.plan Link to comment Share on other sites More sharing options...
solver Posted March 15, 2016 Share Posted March 15, 2016 Pro has multiple advantages, a big one is the ability to draw your own roof planes. If you are considering the upgrade, I'll suggest you download the trial. There is some learning, but you will be able to see what you can do with it. Link to comment Share on other sites More sharing options...
LawB10 Posted March 15, 2016 Share Posted March 15, 2016 solver, There's no time limit(s) on the Trial version. I've had Pro since August of 2015 and Premier since November of 2015 Both still work. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 15, 2016 Share Posted March 15, 2016 The double lines you mention look like walls that you made invisible. Upgrading will not fix your lack of understanding of how to properly use the software. All I see is a plan file created by a new user who has not well studied and understood how the software is designed to work. That is the main purpose of the Reference Manual to answer the questions of How do I get a particular result and why. Do some studying not some upgrading. DJP 1 Link to comment Share on other sites More sharing options...
LawB10 Posted March 15, 2016 Share Posted March 15, 2016 The double lines you mention look like walls that you made invisible. Upgrading will not fix your lack of understanding of how to properly use the software. All I see is a plan file created by a new user who has not well studied and understood how the software is designed to work. That is the main purpose of the Reference Manual to answer the questions of How do I get a particular result and why. Do some studying not some upgrading. DJP I agree with this post, well said David.... Link to comment Share on other sites More sharing options...
katalyst777 Posted March 16, 2016 Share Posted March 16, 2016 I think some other responders misread the question and didn't look at the plan/screenshot very closely. The double lines in the ROOF along the right of your manual bay bumpout have to do with the location of your invisible wall, if you move it slightly to the right a bit more, you won't get the second roof plane generating there.Once you get the roof how you want, turn UNCHECK Auto Rebuild Roofs in the Build Roof dialog, then you can delete those little extra rooms created with room dividers and still have the roof remain intact the way you want. Link to comment Share on other sites More sharing options...
