Designer_Ryan Posted yesterday at 10:45 PM Share Posted yesterday at 10:45 PM The garage has a default of negative 3-1/2" when the monolithic slab is created. How can I assign this to defaults for different rooms? I'm wanting my floor defaults for the house front entry and rear entry, monolithic slab, to be negative 3-1/2". Thanks. Link to comment Share on other sites More sharing options...
y-g-m-n Posted 12 hours ago Share Posted 12 hours ago open defualts goto rooms go to actual room you want to change defualts Open and edit structure. but why? garage is lowered so any water dripping from car does not roll into house, Link to comment Share on other sites More sharing options...
solver Posted 7 hours ago Share Posted 7 hours ago 5 hours ago, y-g-m-n said: Open and edit structure. Could you show where to set the floor to -3 1/2? Link to comment Share on other sites More sharing options...
Designer_Ryan Posted 6 hours ago Author Share Posted 6 hours ago I opened and edited Structure for the floor Lanai. The only option I see is Floor Finish. I set floor finish to -3-1/2". The floor did not drop 3-1/2", like the garage floor. Right now I'm having to set these types of floors: lanai, shower, front entry as garage and change the names. Link to comment Share on other sites More sharing options...
Jo_Ann Posted 5 hours ago Share Posted 5 hours ago floor Lanai ?????????? Link to comment Share on other sites More sharing options...
Rookie65 Posted 3 hours ago Share Posted 3 hours ago "Floor finish" means the thickness of the finished floor material. The structure would be where you'd drop it like a garage or deck. Unless your wording is incorrect? Link to comment Share on other sites More sharing options...
