grnbuildthebasin Posted January 21, 2024 Share Posted January 21, 2024 I need to add a glass sliding door on this wall under this window (where circled) but HD Pro 2024 won't let me. There was a door here under the window but at some point it seems to have disappeared and now i can't put it back. Any idea why?? Link to comment Share on other sites More sharing options...
Robborito Posted January 21, 2024 Share Posted January 21, 2024 21 minutes ago, grnbuildthebasin said: Any idea why?? I have had similar issues in the past; I would save the window in your user library - then add a door to the wall you want - then reinsert the saved window at the appropriate floor level plan. It looks like the sill of the window is below the ceiling/top plate height - that may have caused it to delete the door in preference and save the window with the raked head; A door and window wont site together in plan if they clash with height references - from my experience anyway. I adjust window positions in elevation in preference. Cheers. Link to comment Share on other sites More sharing options...
solver Posted January 21, 2024 Share Posted January 21, 2024 6 hours ago, Robborito said: I would save the window in your user library - then add a door to the wall you want - then reinsert the saved window at the appropriate floor level plan. Cut the window, place door, Paste/Hold Position to put the window back. Link to comment Share on other sites More sharing options...
solver Posted January 21, 2024 Share Posted January 21, 2024 Link to comment Share on other sites More sharing options...
grnbuildthebasin Posted January 22, 2024 Author Share Posted January 22, 2024 Thanks both. Deleting the window and putting everything back worked. Link to comment Share on other sites More sharing options...
y-g-m-n Posted January 23, 2024 Share Posted January 23, 2024 reason why was program will not put a door in the window in plan view. NExt time place them in the wall where ever they fit and then move them to where you want. makign sure window is at elevation to clear door and any framing you may have. Link to comment Share on other sites More sharing options...
