Different roofing materials on same structure
jordanoja
Go to solution Solved by ChiefArchitect,
I tried to do what you said in Suite and in Architectural with no success, I do know that if you had Home Designer Pro and a few additional steps, you would be able to do what you wanted to do, just not in Suite or Architectural or Essentials. I am sorry but often is the case that you only get what you pay for.
  • Solution
Hi jordanoja,
Thanks for using Suite.
Once the roof is in place, then un-check "Auto Rebuild Roofs" on the "Build>Roof>Build Roof..." menu.
Select the Material Painter tool (looks like a spray-paint can) and choose your new roofing material from the library.
Then just click on the roof plane to apply the chosen material.
  • 11 years later...
