Londailey Posted November 4, 2020 Share Posted November 4, 2020 Using Pro: I have a shower floor but the drains from the Library don't integrate with the floor (can see the floor through the grating). The drain just sits on the floor. How to fix this? Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 4, 2020 Share Posted November 4, 2020 This is a possible solution, take a look please, DJP 1 Link to comment Share on other sites More sharing options...
Robborito Posted November 5, 2020 Share Posted November 5, 2020 My suggestion is - it works for me as a work-around; And as I say - its just 'my' work around as a solution that I have used. firstly - Label the room as 'open below'; this removes the default floor; the draw a CAD circle the size & where you want it; Then insert two floor slabs that centre around the hole you want; Mine are off centre for this demo; Add a few points or 'breaks' to enable making a round hole, or half a round hole on each slab edge; add your finish; add your floor waste plumbing object; ( i did not do this bit, again for clarity ) Then- take a break. Happy hole cutting. 1 Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 5, 2020 Share Posted November 5, 2020 It would be much simpler to just add a vertical cylinder (same size as the drain), .25" height, painted black. Then slide it under the drain. 1 Link to comment Share on other sites More sharing options...
RobinD Posted November 18, 2020 Share Posted November 18, 2020 On 11/4/2020 at 12:03 PM, Londailey said: Using Pro: I have a shower floor but the drains from the Library don't integrate with the floor (can see the floor through the grating). The drain just sits on the floor. How to fix this? Where did you find the drain itself? I'm using HD Pro as well but can't find the drain in the library.... Link to comment Share on other sites More sharing options...
Londailey Posted November 18, 2020 Author Share Posted November 18, 2020 type in "shower drain" in the search field. There are three to choose from. Link to comment Share on other sites More sharing options...
tkid124 Posted December 2, 2020 Share Posted December 2, 2020 On 11/17/2020 at 7:40 PM, Londailey said: type in "shower drain" in the search field. There are three to choose from. These are Kohler products, you may need to download the catalog. Link to comment Share on other sites More sharing options...
