all doors show exterior?
AndyT05255
Your interior doors are interior doors. If you are asking because you see the Exterior I have circled, that is the program showing one side of the door. This is a 3D view and may be rotated around to see the other side.
To change the doors, select and use the Library button to choose one.
To change all the doors in the plan at once, click on the door icon as if you wanted to place one. Hold the Shift key and marquee around the plan. Ctrl-E to open the Door Specification dialog. Click Library and choose a new style.
When you are beginning a new plan, you may set up your defaults, and doors placed afterwards will match them.
