LindaM Posted February 15, 2020 Share Posted February 15, 2020 How do I upload my plan when it exceeds the max size? Link to comment Share on other sites More sharing options...
solver Posted February 15, 2020 Share Posted February 15, 2020 You can use Edit Area to select just a portion of the plan, copy, paste into a new plan and upload it. Copy the plan and remove all the cars, furniture etc. Zipping the plan will sometimes get it small enough. Link to comment Share on other sites More sharing options...
LindaM Posted February 16, 2020 Author Share Posted February 16, 2020 Ok thank you, I'll give it a try tomorrow. I have an ongoing mirror reflection issue and the under cabinet lighting issue. Hoping to find a solution eventually. Link to comment Share on other sites More sharing options...
LindaM Posted February 16, 2020 Author Share Posted February 16, 2020 I cannot get the lights to shine, only show as gray circles on counter. UNDER_CABINET_LIGHTING_HELP.plan Link to comment Share on other sites More sharing options...
solver Posted February 17, 2020 Share Posted February 17, 2020 For problems like this, just poke around the settings and try a few things. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 17, 2020 Share Posted February 17, 2020 YouTube video and edited file: DJP Under_Cab_lighting.zip Link to comment Share on other sites More sharing options...
solver Posted February 17, 2020 Share Posted February 17, 2020 Quick followup to David's video. Watch on YouTube: http://youtu.be/V8gtR05z3Jc?hd=1 Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 Wow Eric and David, thank you! I briefly looked at David's and will review suggestions more later today. David, regarding the island countertop material; it's all the same material, white carrara however, it is not clear unless I move the cabinets further away from each other which doesn't work because then I have gaps. So, I don't know what's going on with that.... Looking forward to sitting on learning from these two videos! I'm wondering, if anything done here could be related to why my mirror reflections have not been working? Link to comment Share on other sites More sharing options...
solver Posted February 17, 2020 Share Posted February 17, 2020 10 minutes ago, LindaM said: So, I don't know what's going on with that.... Align the cabinets. Should not matter, but the one on the left is a bit off. 11 minutes ago, LindaM said: here could be related to why my mirror reflections have not been working? Examples? Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 Ongoing issue with mirror not reflecting. Mirror_Not_Reflecting.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 17, 2020 Share Posted February 17, 2020 Look in that plan's settings "Edit - Default Settings - Camera - Show Reflections", it is probably unchecked there. DJP Link to comment Share on other sites More sharing options...
solver Posted February 17, 2020 Share Posted February 17, 2020 No problems here. Are reflections on for your camera? 1 Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 Yes they're on...... Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 17, 2020 Share Posted February 17, 2020 When opening your plan in Windows 10, the 3d cam shows the mirror correctly. I started a new plan, and placed the same mirror (from the library) in the new plan. The 3d cam shows the mirror correctly. So, I used the rainbow tool to see the define material boxes of the mirror in each plan. The material color settings and the properties settings are both identical, in each plan.However, the kettles do not look the same. ??? You are using a mac and maybe that has something to do with it?OR, maybe check the settings for the graphics card on your laptop. This might be something that tech support can help with. 1 Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 David nothing you did has changed in mine. I got one puck to work, the others aren't changing, revising the setting to "dusk" was non eventful as well. I can't get the glare and brightness to change. My lightbulbs in the pendant lights aren't on either. Thank you for the great video! Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 This glare! I can't get rid of it, set to dusk no change.... Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 Eric, I watched your video and the puck lighting suggestions worked, I think. It's so very bright in my drawing that I can't really tell yet until I get the glare fixed. Going to call tech support. Thank you! Link to comment Share on other sites More sharing options...
solver Posted February 17, 2020 Share Posted February 17, 2020 (edited) 55 minutes ago, LindaM said: I got one puck to work, the others aren't changing, Which one? What did you change? Did you watch my video? And make sure your video card driver is up to date. Edited February 17, 2020 by solver No sound on video 1 Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 The puck light that changed I think is the one to the right of the stove. Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 Making headway with your video Eric, thank you. Need to work on reflections next..... Link to comment Share on other sites More sharing options...
solver Posted February 17, 2020 Share Posted February 17, 2020 Video with sound. Watch on YouTube: http://youtu.be/u08YCkIEG7E?hd=1 Link to comment Share on other sites More sharing options...
LindaM Posted February 17, 2020 Author Share Posted February 17, 2020 Thanks Eric. Mine looks same with the exception of countertop, pendant bulbs over island are not illuminated and mirror not reflecting. I'll have to figure out the video card and how to determine if it needs updating when it says "automatic". I appreciate all your help! Link to comment Share on other sites More sharing options...
