2build 0 Posted January 26, 2020 I am trying to get HD Pro to put a simple shed roof over my rectangle. I created one long wall to be 8'. The other is 12' by setting in the component object although the 3d view without the roof shows all the walls at the same height. The ends are set to shed roof. When I build a single roof plane, It either generates the plane at a ridge height of almost 30 ft, or cuts my wall and makes a flat roof. what am I doing wrong? Share this post Link to post Share on other sites
2build 0 Posted January 26, 2020 I was able to stretch the walls manually, but I still can't get the roof drawn correctly. I have also changed all the interior walls to attic walls, but don't know how to regenerate their height to match the outside walls. florence trapazoid.plan Share this post Link to post Share on other sites
DavidJPotter 207 Posted January 26, 2020 https://youtu.be/WasdN_LYi_o No need to stretch the walls if you set the walls up properly (see the link to a YouTube Tutorial video please) DJP 1 Share this post Link to post Share on other sites
2build 0 Posted January 27, 2020 Thanks. I figured how to make a roof pane to manually get the shed roof. I guess my issue with the cut in the wall is that the roof is following the slope. If I delete the roof, reduce the wall height to standard and let the gable take it to the top of the shed, will all my interior walls get rebuilt as attic? Share this post Link to post Share on other sites
LawB10 11 Posted January 28, 2020 Why are you manually doing that? What solver showed you is the easiest for that design. You are not going to get much of a shed with a 1" pitch. Start by turning on auto rebuild roofs, then build a 2nd floor, start with a 8" pitch, gable the side walls and high shed the front wall, click on the back wall and lower the pitch. Share this post Link to post Share on other sites
