Changing default material has no effect (walls)
4ndrew
Simply, I want to make the default color for the interior side of exterior walls white.
If I draw a wall without changing the default color (tan), then change the default color to white, it has no effect, and newly drawn walls still use the default tan color.
How can I get this to work?
thanks
Hey David - thanks as always for the help!
It appears that the color (pattern) must be selected via the Wall Types dialog; if edited in Materials, it only changes the fill color, which seems to be overridden by the Pattern in the Wall Types > Define dialog.
I'm going to experiment a bit more, but I'm not sure why, exactly, the Material Defaults dialog doesn't work.
  • 3 years later...
Thanks for the video, David.  I am trying to follow what you did in changing the defaults for wall materials, but when I click on Walls in the Default menu I get a much more limited menu see below).  I can only choose which type of wall (Siding-6, etc.) is the default for Exterior and Interior walls, but there is no ability to change the default setting for how different types of walls are constructed or appear.  I am trying to find a way to change the default material for Interior walls to something besides drywall without having to go through and spray paint some other material on every wall.  I am running Suite 2021, perhaps this is a limitation of this version.
Thanks for any help.
What you are seeing is probably a limitation of Suite, but you can paint a material everywhere in plan with a single click -- no need do every wall.
Read about using the Material Eyedropper.
