DIYAdam Posted February 6, 2018 Share Posted February 6, 2018 Hello DIY users I'm trying to create a box out style chimney that extends thru the gable roof line and can't seem to get the walls to work. There seems to be some conflict between the gable roof and possibly a attic wall. I tried the soffit technique but it worked but, it didn't show the framing in floor plan view. Link to comment Share on other sites More sharing options...
solver Posted February 6, 2018 Share Posted February 6, 2018 Pull the roof planes back. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 6, 2018 Share Posted February 6, 2018 Roof planes are programmed to cut off walls that are under the plane of the roof planes. So like Eric said, edit the edges of the roof planes in the area of the chimney walls, so they are not interrupted by roof plane edges. DJP Link to comment Share on other sites More sharing options...
DIYAdam Posted February 6, 2018 Author Share Posted February 6, 2018 Ok.. I have move back the roof planes to where they do not interfere with the walls below but no visible wall. When I select the area where there is no wall the selection preview shows the wall at full height of the other walls so there I must have some thing still conflicting. and for a off subject question whats the best way to upload screen shots I have been using the snipping tool saving them then drag to the forum upload tool? Link to comment Share on other sites More sharing options...
solver Posted February 6, 2018 Share Posted February 6, 2018 The chimney should be defined as a room. Try making the ceiling 300". Link to comment Share on other sites More sharing options...
DIYAdam Posted February 6, 2018 Author Share Posted February 6, 2018 Alright success... what I did was go in to the "living" room definition uncheck ceiling over this room and the rebuild was successful however there needs to be some siding above the shingles the software is still treating the wall as a interior wall type... probably because I created the wall that way now just need to have some help changing the area above the roof. Link to comment Share on other sites More sharing options...
solver Posted February 6, 2018 Share Posted February 6, 2018 Read up on Lower Wall Type When Split by Butting Roof. You need to change that wall to exterior, then set the lower wall type to interior. Link to comment Share on other sites More sharing options...
LawB10 Posted February 6, 2018 Share Posted February 6, 2018 Why not use the fireplace tool, Click Build>fireplace and then change the height, to get the chimney. 1 Link to comment Share on other sites More sharing options...
GTboys Posted November 24, 2020 Share Posted November 24, 2020 Hello Gentlemen, I'm struggling with this as well. There are many components of what has already been discussed that I understand. 1) I understand that you need to create a "room" and have the ceiling height rise above the roof line 2) I understand how to modify the roof plane so that it goes around the 4 "walls" of the chimney 3) I understand how to reverse wall layers and how to use "lower wall type if split by a butted roof" Somehow I can't put it all together. I'm wondering if it has to do with how I'm drawing my walls initially? I've tried the following: 1) Had my main structure first, then tried to make the chimney "box" with three exterior walls abutted to the main structure (and adding "breaks" to the main wall) 2) Created a 4 wall structure away from the main structure and move it up next to the the house 3) Create a "hole" in the main structure and moved a 4 wall box into the hole. Nothing seems to be working. The odd thing is that I think I actually got it to work once. Not sure what I did. Link to comment Share on other sites More sharing options...
solver Posted November 24, 2020 Share Posted November 24, 2020 @GTboys Best to start your own thread when you have a question. Please do so, and delete your comment above (click Options). Also tell us what's not working -- and adding a couple of images will help too. Link to comment Share on other sites More sharing options...
