Kellyselko Posted January 15, 2018 Share Posted January 15, 2018 Please view the attached images. Using Home Design Architect, I would like to change the roof from the current shabin image to the ideal shabin image. The shabin is 1 and1/2 stories with a dormer on the back. In my ideal design the main roof is a 12 pitch gable that transitions into a 4 pitch shed covering a porch. What is the technique to create this shed style roof? Craig and Kelly Link to comment Share on other sites More sharing options...
Kellyselko Posted January 15, 2018 Author Share Posted January 15, 2018 Just now, Kellyselko said: Please view the attached images. Using Home Design Architect, I would like to change the roof from the current shabin image to the ideal shabin image. The shabin is 1 and1/2 stories with a dormer on the back. In my ideal design the main roof is a 12 pitch gable that transitions into a 4 pitch shed covering a porch. What is the technique to create this shed style roof? Craig and Kelly Ideal Shabin Current Shabin Link to comment Share on other sites More sharing options...
solver Posted January 15, 2018 Share Posted January 15, 2018 Check the Build Rood Dialog, Roof Styles. Read up on the Gullwing roof type. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 15, 2018 Share Posted January 15, 2018 Share a copy of your .plan file and I will show you how in a video. DJP Link to comment Share on other sites More sharing options...
Kellyselko Posted January 15, 2018 Author Share Posted January 15, 2018 37 minutes ago, Kellyselko said: Please view the attached images. Using Home Design Architect, I would like to change the roof from the current shabin image to the ideal shabin image. The shabin is 1 and1/2 stories with a dormer on the back. In my ideal design the main roof is a 12 pitch gable that transitions into a 4 pitch shed covering a porch. What is the technique to create this shed style roof? Craig and Kelly Ideal Shabin Current Shabin Shabin, Kelly 2.plan Link to comment Share on other sites More sharing options...
Kellyselko Posted January 15, 2018 Author Share Posted January 15, 2018 17 hours ago, Kellyselko said: Please view the attached images. Using Home Design Architect, I would like to change the roof from the current shabin image to the ideal shabin image. The shabin is 1 and1/2 stories with a dormer on the back. In my ideal design the main roof is a 12 pitch gable that transitions into a 4 pitch shed covering a porch. What is the technique to create this shed style roof? Craig and Kelly Ideal Shabin Current Shabin Link to comment Share on other sites More sharing options...
Kellyselko Posted January 15, 2018 Author Share Posted January 15, 2018 I think I figured it out. You need to: To turn off the display of attic walls 1. In floor plan view, select Tools> Display Options (or press the ~ key) to open the Layer Display Options dialog. 2. Find "Walls, Attic" in the Name column, remove the check from the Display column for this item, and click OK. For more information, see “Layer Display Options Dialog” on page 145 of the Reference Manual. After you do that then you define your porch side walls as high shed/gable wall under wall specifications. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 15, 2018 Share Posted January 15, 2018 Here is your video I promised, done in Architectural 2018: DJP 1 Link to comment Share on other sites More sharing options...
LawB10 Posted January 16, 2018 Share Posted January 16, 2018 Here's a version of the plan/image... shabin-1.plan Link to comment Share on other sites More sharing options...
Kellyselko Posted January 18, 2018 Author Share Posted January 18, 2018 Thank you guys for all your hard work and help. Its looking very good. I was able to tell the plan, early on, that I wanted 2x6 studs, centered on 24" in the walls. But I haven't been able to find where I can specify the size of board 2x12 in the roof, and maybe spacing on the 24 there as well." It looks easy to do in pro, but I haven't figured out this issue in architectural. Any clues? Kelly and Craig Link to comment Share on other sites More sharing options...
solver Posted January 18, 2018 Share Posted January 18, 2018 Only Pro has the ability to specify roof structure. Link to comment Share on other sites More sharing options...
