hoosierxsooner Posted July 17, 2017 Share Posted July 17, 2017 I have this deck on the back of house. I have a vaulted ceiling over the great room. The ceiling over this door should be parallel to the floor; I have same issue on opposite side of room as well. Over the entry. I have attached my plan. ceiling deck cab udated 7 14.plan I am sorry if this has already been answered could not find it. Pam Home Designer Suite 2017 Link to comment Share on other sites More sharing options...
solver Posted July 17, 2017 Share Posted July 17, 2017 Is this what you want? Link to comment Share on other sites More sharing options...
LawB10 Posted July 17, 2017 Share Posted July 17, 2017 Open the living room specification box and check "ceiling over this room". Link to comment Share on other sites More sharing options...
solver Posted July 17, 2017 Share Posted July 17, 2017 Nothing wrong with your plan -- I was bored and decided to see how it might look a bit different. Link to comment Share on other sites More sharing options...
hoosierxsooner Posted July 17, 2017 Author Share Posted July 17, 2017 11 hours ago, solver said: Is this what you want? Yes!! How did you do that? Thanks Pam Link to comment Share on other sites More sharing options...
hoosierxsooner Posted July 17, 2017 Author Share Posted July 17, 2017 9 hours ago, LawB10 said: Open the living room specification box and check "ceiling over this room". If I do that it takes away the vaulted ceiling completely. Thanks Link to comment Share on other sites More sharing options...
solver Posted July 17, 2017 Share Posted July 17, 2017 2 hours ago, hoosierxsooner said: Is this what you want? Yes!! How did you do that? Thanks Pam I used a tool Suite does not have. Hopefully someone else will respond with an idea. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 17, 2017 Share Posted July 17, 2017 The missing tool in Suite is called "Custom Ceiling Planes" which only Home Designer Pro and Chief Premier have. You can repair the interior vaulted ceiling by covering the void with a custom slanted soffit (found under cabinet tools), It will have to be made very thin, probably 1" thick so it only appears to the interior, otherwise it will also be seen in exterior and exterior overview views but can be done in Suite with ease. DJP Link to comment Share on other sites More sharing options...
hoosierxsooner Posted July 17, 2017 Author Share Posted July 17, 2017 How do you tilt the soffit? Pam Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 17, 2017 Share Posted July 17, 2017 Pam, my apologies in that I assumed that Suite was enabled for soffits to be slanted. After checking in Suite 2017 I found that this is not the case. In the ensuing versions since I last looked this feature has been removed by Chief Inc. I suppose your only choice is to make a symbol using Sketch Up and then importing that object into Suite as a symbol and then placing that symbol where you need it to cover the gable hole in the ceiling or you can upgrade to Architectural 2018 that does have the sloped soffit feature in it. I am sorry for the misinformation earlier posted by me. DJP Link to comment Share on other sites More sharing options...
hoosierxsooner Posted July 17, 2017 Author Share Posted July 17, 2017 Not a problem. Might just live with it. Thanks Pam Link to comment Share on other sites More sharing options...
