Helicoidal Staircases
sarahgh
Hello,
i need to try out some helicoidal stairs in a restricted space. I have only found cad that is incompatible with the program
I cannot make the stairs within the program, although there probably is a way that i am missing.The spiral staircases dont do the job. Also i want to extend at the bottom after they have curved in the circle.
What i am after is something like these
http://www.rizziscale.com/eli-ca-03-144
in the smallest size
Any tips?
Thank you
144-helical_staircase-data-sheet.pdf
No one can help you until and unless you also state what software and its version number that you are using. What do you have please? Depending upon what software you have you should be able to curve stairs, turn off the railings (again depends completely upon what software you have) then just use the stair dialog to edit the style and turn railings off. It takes some practice but I know can be done in Home Designer Pro, I am not sure about  in other Home Designer titles and versions.
Here is a Chief Premier X6 user who made a video of such a stair, after you get just the right dimensions and diameter you merely turn off the railings and suppress the stringers
Sorry, didnt realise - its home designer suite 2018
Yes i can curve stairs with this, however it wont seem to believe me on how curved and how small i need them. ie 125cm diameter hole .In order to reach the next floor the brogram wants a lot more space than this.
Thought someone might have a compatible cad
Thanks for your help
hi all, believe it or not this will be an improvement on the existing spiral staircase elsewhere in the house!
This is to fit in a tiny room in a medieval house in a mountain village in Italy.
We are restricted by - the mountain , the immensely thick stone walls and the need to steer away from load bearers,
I wish we could fit a 'normal' one
As a compromise we hope that helicoidal will be - more usable, not scarily see through and the dog will be able to negotiate it
we are adding an extra couple of rooms to this: https://www.homeaway.com/vacation-rental/p401226
Thanks for all the help
