Second story has no floor HELP!
rv4life
Go to solution Solved by rv4life,
Hello,
I am trying to model a hotel property.  Everything has been going well until I noticed about half of my second floor rooms are missing the button floor and you can see to the first floor.  This happened in the past on the first floor due to the foundation not being over the area or missing walls.  That problem was quickly resolved.  This time, I have checked all the walls, and they are all there.  I noticed this issue because every time I would attempt to place a second story window, it would put it on the first floor.  I have noticed that on the first floor, some walls are randomly taller than other walls.  Could this be the issue?  I have deleted and remade some of the taller walls but it keeps placing them at the same heights.  I have attached pictures of the issue.  Any ideas?  As you can see in the pictures, the first floor looks normal but has odd wall heights that I cannot seem to change, and the second floor looks normal but has no floor where the walls had higher heights from the first floor.
Thank you for your help!
Shane Carman
Check your Room Specifications > Structure, and make sure settings are the same in all rooms.
Second floor make sure rooms are defined and not Open Below.
Thanks for the info. I set the rough height of the walls to 102", which seemed to lower the walls back to where they normally were.  Some rooms will not lower to the same place and the rooms still have no floor.  Also, where is the open below option?
Thank you!
You can also use free services like "Google Drive" and "Dropbox" for files too large for directly posting here (you post a hyperlink to such files instead of the file) so any size file can easily be shared thereby here.
Thanks!  If I upload the plan, would you mind taking a look?  Thank you again!
Thanks for all of your help folks!
Here is the link to the DXF / CAD file: https://drive.google.com/file/d/0B64tWtsMY6d1U1NMcXBhcTVVOEE/edit?usp=sharing
Here is the link to the actual plan file that opens the plan: https://drive.google.com/file/d/0B64tWtsMY6d1b0Y3ZFkzeEE0MVU/edit?usp=sharing
If you go to the second floor, you will see that some of the rooms do not have a floor.  I also noticed that the walls, mainly on the first floor, were all different in height.  I went to areas of the building that did not have this problem and their finished ceiling height was 107 5/8".  I went to the rooms with the issue and adjusted the finished ceiling height in most of them to 107 5/8".  While this lowered the walls back to a normal level, it still looks strange and there is no upstairs floor.  I would appreciate any support you can offer.
Thank you!
By the way, did you enclose your second floor with walls when you ordered it created? No walls equals no floor or walls and I see in your images no floor or walls that define the second floor. What did you do or not do please?
PS: I am busy working on a couple of paid projects and thus have little time for gratis work, sorry. You post the plan and others can at least look and help
Yes I did enclose the second floor prior to placing the rooms.
You should really complete the Structure BEFORE you start placing furniture ,cabinets etc ,  the .Plan file is 63 mb already !  :)     there are also a number of textures missing as you didn't do a full "backup of the entire plan" and zipping the save folder to post.
Will have a look using the 2015 Trial since I am on Pro 10
There are still a number of rooms set to 120+ " for finished ceilings etc instead of 109"
