Graymor Posted April 3, 2017 Share Posted April 3, 2017 When I create a rail-less deck on the ground floor, and a railed deck above that on the 2nd floor, the posts for the second floor deck will not show. If I delete the ground floor deck, the posts show. How can I get them to stay showing (pass through the ground floor deck to support footings) with the ground floor deck in place? Any thoughts? Link to comment Share on other sites More sharing options...
Graymor Posted April 3, 2017 Author Share Posted April 3, 2017 You are correct. I used CA many, many years ago, and just bought the new version last night. I am using the 2018 Home Suite, and trying to get a feel for it by recreating my existing home as-is. I will go in and create a terrain model now, based upon your comments, and the fact that I just finished watching the video on walk-out basements, which I have. Link to comment Share on other sites More sharing options...
Graymor Posted April 3, 2017 Author Share Posted April 3, 2017 And, thanks for the pointer on the signature. I just did that now. Link to comment Share on other sites More sharing options...
solver Posted April 3, 2017 Share Posted April 3, 2017 My Terrain comment was not directed at you. I copy and paste that entire block when I see a new user, and forgot to delete it and make a proper comment on your question. Suite is limited when it comes to being able to automatically do this. Its been discussed before, and a forum search will likely turn up some useful info. You could make your own post from soffits as I've shown here, or from a Solid Shape found in the Library. Link to comment Share on other sites More sharing options...
Graymor Posted April 3, 2017 Author Share Posted April 3, 2017 i was going to try that, but could not find anywhere in the menu's where I could add my own posts. Columns, yes, but no posts... Making my own posts would be fine, as my posts for my upper deck aren't where a plan model would "automatically" put them. Is the "architecture" version better at decks? Or just a flaw of CA in general? Link to comment Share on other sites More sharing options...
solver Posted April 4, 2017 Share Posted April 4, 2017 All the Chief Architect products have issues with this -- not just decks one above the other, but rooms over porches, decks over rooms etc. Home Designer Pro allows you to modify program generated framing and create your own framing members as needed. Pro also lets you create a railing with posts and a beam. I'm not familiar with the capabilities of Architectural. You could get the trial for Architectural and try it. Link to comment Share on other sites More sharing options...
RRBRUCE Posted June 10, 2017 Share Posted June 10, 2017 (edited) Hi, Have been reading these posts and use Pro 2018. I also am trying to build a deck over a deck and supports are not generating correctly at all. I am fairly new to this. Above, Solver says Quote Home Designer Pro allows you to modify program generated framing and create your own framing members as needed ..... Any clues/tips/tricks help on doing this? Its two basic decks. 40'X6' 8". Nothing fancy on terrain etc. Below is image of my file. Edited June 10, 2017 by RRBRUCE Forgot Some Info Link to comment Share on other sites More sharing options...
RRBRUCE Posted June 10, 2017 Share Posted June 10, 2017 No Solver, I didnt miss it. And whether you believe me or not I was actually able to find those pleasantly generic and unspecific help menus/videos all by my little ol self, it was a proud moment. You seem to have the same attitude that Chief Architect has had since I first worked with them in 1996. Have you been there the whole time? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 11, 2017 Share Posted June 11, 2017 1 hour ago, RRBRUCE said: No Solver, I didnt miss it. And whether you believe me or not I was actually able to find those pleasantly generic and unspecific help menus/videos all by my little ol self, it was a proud moment. You seem to have the same attitude that Chief Architect has had since I first worked with them in 1996. Have you been there the whole time? Me thinks you are the one with the "attitude" and chip on your shoulder. Eric is all about "Help" as are most of us here. If by "attitude" you mean one should be personally responsible for their successes or failures, then I agree. DJP Link to comment Share on other sites More sharing options...
LawB10 Posted June 11, 2017 Share Posted June 11, 2017 On the bottom deck, click on the rails and check post to ceiling. Link to comment Share on other sites More sharing options...
RRBRUCE Posted June 11, 2017 Share Posted June 11, 2017 Thanks LawB10, Looking forward to trying that. Made a little progress manually moving framer members around but still not happy with it. Thanks and have a great evening!! Link to comment Share on other sites More sharing options...
