Barrel Cielings
PLANsLLC123
Go to solution Solved by PLANsLLC123,
Short answer:  yes ... with a qualifying "but"
If you want to stay completely within HDPro, you can adapt the following knowledge base article for your use by using ceiling planes rather than roof planes:
https://www.homedesignersoftware.com/support/article/KB-01187/creating-a-barrel-roof.html
The "but" is that the method is tedious and exacting ... not much fun to create and not very flexible when modifying the model for future changes.
Instead, consider creating a triangular prism-like object with a concave bottom in SketchUp and then import that into your model.  Create using approximate dimensions in SketchUp and then tweak fit it into your model in HDPro.  This method is much quicker and easier.
Good luck and hope this helps. :)
