Kohler vanities
Rapidnurse
Go to solution Solved by katalyst777,
The 2 pics show how they work.
The pic on the left is a base cabinet from the library and a sink from the Kohler catalog
The one on the right is a Kohler Vanity and a sink from the library. You have to lower sink down into the vanity a inch or two and use a soffit or custom counter top.
The reason it sits on top is because it was designed that way or it's from 3d warehouse.
When you tried to place the sink, you should have gotten message, if you did not, then the software doesn't recognize the object
  • 11 months later...
