Rapidnurse Posted May 18, 2016 Share Posted May 18, 2016 I like Kohler's vanities, but has anyone figured out how to place the sinks into them? HD Arch 17. Link to comment Share on other sites More sharing options...
solver Posted May 18, 2016 Share Posted May 18, 2016 What Kohler vanities are you referring to? Link to comment Share on other sites More sharing options...
LawB10 Posted May 18, 2016 Share Posted May 18, 2016 Download the Kohler catalog from the Home Designer website. The objects work the same as the ones from Library Link to comment Share on other sites More sharing options...
Rapidnurse Posted May 19, 2016 Author Share Posted May 19, 2016 The objects do not work the same as the ones from the library. I have to use a shelf to put on top, and you can't put the sink in but you can place them on the top. Link to comment Share on other sites More sharing options...
LawB10 Posted May 19, 2016 Share Posted May 19, 2016 The 2 pics show how they work. The pic on the left is a base cabinet from the library and a sink from the Kohler catalog The one on the right is a Kohler Vanity and a sink from the library. You have to lower sink down into the vanity a inch or two and use a soffit or custom counter top. The reason it sits on top is because it was designed that way or it's from 3d warehouse. When you tried to place the sink, you should have gotten message, if you did not, then the software doesn't recognize the object 1 Link to comment Share on other sites More sharing options...
Solution katalyst777 Posted May 23, 2016 Solution Share Posted May 23, 2016 In other words, sinks get placed in cabinets with countertops. The Kohler vanity symbols aren't cabinets so far as the program is concerned, so you can't just place a sink in them. Link to comment Share on other sites More sharing options...
midway22 Posted May 22, 2017 Share Posted May 22, 2017 Is this still the case or has anyone found a way to actually use a kohler sink with their vanity / counter top combo? I am amazed they didn't try such a simple use of their library. Link to comment Share on other sites More sharing options...
