MoreyCarpentry Posted April 25, 2016 Share Posted April 25, 2016 Hey there, I have 2017 Pro. I use the elevation camera tool to make for an example, front elevation. Looks great, BUT when I send to layout it turns into bad quality and when printed looks horrible. How can I get the elevation in the layout to look as good as the elevation camera view? Thanks! Matt. Link to comment Share on other sites More sharing options...
katalyst777 Posted April 25, 2016 Share Posted April 25, 2016 What settings are you choosing in the "Send to Layout" dialog? Click on the Help button (at the bottom of the dialog) to learn what each actually do if you aren't sure. Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 Not completely sure what you are looking for, the Send to Layout dialog doesn't seem to have any quality options. But this is what is selected: Send position: nothing Send Options: Entire Plan/View Camera View Options: Live View > Update on Demand (Camera View Options does not let me change, these are default) Scaling: 1/2" = 1' and Use Layout Line Scaling box is checked Plot Line Options Default Line Weight is 18, Default Pattern Weight is 10 and Merge Generated Lines is checked. Thanks! Matt. Link to comment Share on other sites More sharing options...
marceline Posted April 25, 2016 Share Posted April 25, 2016 Try PLOT LINES instead of LIVE VIEW. Closer? Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 Unfortunately the Plot Line option is not an option I can pick, it is greyed out. Thanks! Matt. Link to comment Share on other sites More sharing options...
marceline Posted April 25, 2016 Share Posted April 25, 2016 Sure your in an elevation when you send? Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 Yup, I'm in an Cross Section/Elevation camera tab. Look great, but when it gets sent to layout it looks blurry, pixelly and when printed out it looks the same. Link to comment Share on other sites More sharing options...
katalyst777 Posted April 25, 2016 Share Posted April 25, 2016 Sounds like 2017 has some options I don't have in 2016. What "Rendering Technique" do you have active when you go to send the view? Elevations are typically "Vector" but your description makes me think you may have switched to something else. If you're not in Vector, can you switch to that rendering technique and then get the options Marcy suggested when sending to layout? 1 Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 I'm using the Technical Illustration View, in the Rendering Technique Options I have turned the warn and cool color to white, warm blend and cool blend to 0%, line thickness to 4. None of these options helps in anyway. Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 This is in the elevation view, looks great! Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 BUT after sending to layout this is what it looks like Link to comment Share on other sites More sharing options...
solver Posted April 25, 2016 Share Posted April 25, 2016 You can post images directly to the forum. No need to put them in a gallery first. They are showing a permission error. Link to comment Share on other sites More sharing options...
marceline Posted April 25, 2016 Share Posted April 25, 2016 Zoom way in on the view in layout. Select the box. Click Update View. Or you can just use the Vector rendering technique, like Kat suggested. 6 Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 Not sure how to add pictures directly. I made another album to see if it works. Here is in elevation camera view, looks fine: Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 Here it is after sending to layout: Link to comment Share on other sites More sharing options...
solver Posted April 25, 2016 Share Posted April 25, 2016 . Link to comment Share on other sites More sharing options...
solver Posted April 25, 2016 Share Posted April 25, 2016 Attaching -- Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 25, 2016 Share Posted April 25, 2016 This You Tube video may help you: https://youtu.be/cKNYRFvTqsA DJP 1 Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 Did this work? Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 marceline, zooming in and then update view does help a bit, but still very bad quality. Good thought though! Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 DavidJPotter, I noticed in your video you mentioned that technical drawings are images, although you can scale it. I will try the vector view and see if that is better. I figured the technical view would have been the best since there are actually options, like line weight and such. Link to comment Share on other sites More sharing options...
MoreyCarpentry Posted April 25, 2016 Author Share Posted April 25, 2016 solver, thanks for the adding image help! I also see in your picture the technical view has quality issues. For elevations, is the vector view the only good quality option for layout? Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 25, 2016 Share Posted April 25, 2016 Vector view is what I use 99% of the time, you can do as you wish. DJP Link to comment Share on other sites More sharing options...
Solution MoreyCarpentry Posted April 26, 2016 Author Solution Share Posted April 26, 2016 Hey there everyone! Thanks for all of your help, it was the view I was using. Technical View is not a good elevation view to use. Vector looks great! Thanks again! Matt. Link to comment Share on other sites More sharing options...
