lmorris Posted April 19, 2016 Share Posted April 19, 2016 I know that Chief Architect allows for layouts to have multiple pages. I have created one sheet which has the Full Perspective as a First page but now want to create drawing sheets for Floor Plans, Elevations etc. How do I create a drawing set consisting of many layout sheets in Home Designer Pro? Link to comment Share on other sites More sharing options...
solver Posted April 19, 2016 Share Posted April 19, 2016 Open a layout, send something to it, close it. Repeat as needed. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 19, 2016 Share Posted April 19, 2016 You Create a layout file for each printed page that you require (Floor Plan.layout, elevations.layout, electrical plan.layout etc). DJP Link to comment Share on other sites More sharing options...
WBLaney Posted February 26, 2018 Share Posted February 26, 2018 There has to be a better solution than this....is there? Link to comment Share on other sites More sharing options...
solver Posted February 27, 2018 Share Posted February 27, 2018 15 minutes ago, WBLaney said: There has to be a better solution than this....is there? The "better solution" is called Chief Architect Premier. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 27, 2018 Share Posted February 27, 2018 35 minutes ago, WBLaney said: There has to be a better solution than this....is there? For Home Designer Pro that IS the ONLY solution that comes with it, as Eric said, an easier solution is built into Chief Premier by its defaults. DJP Link to comment Share on other sites More sharing options...
WBLaney Posted February 27, 2018 Share Posted February 27, 2018 Great! I used to be on Premier....that's why I was wondering. So then do you have to save separate plans plus separate layouts then? If you want to only show specific layers (like turning off and on electrical say) then you have to save seperately? But then if you have to fix something - you have to go and fix all plans you saved? Link to comment Share on other sites More sharing options...
Rookie65 Posted February 27, 2018 Share Posted February 27, 2018 You do it from one plan. Send to layout what you want/need, save that layout sheet, then create the next. Link to comment Share on other sites More sharing options...
Handi-man Posted March 1, 2018 Share Posted March 1, 2018 In the 'Help' of Home Designer Professional 2018 when I searched for 'library browser' it shows a window with a Library Browser tab and a Project Browser tab with multiple pages for one layout. Do the above comments refer to a older version? Or is the help incorrect? Link to comment Share on other sites More sharing options...
solver Posted March 1, 2018 Share Posted March 1, 2018 3 minutes ago, Handi-man said: In the 'Help' of Home Designer Professional 2018 when I searched for 'library browser' it shows a window with a Library Browser tab and a Project Browser tab with multiple pages for one layout. Do the above comments refer to a older version? Or is the help incorrect? Are you a Pro 2018 user? Link to comment Share on other sites More sharing options...
Handi-man Posted March 1, 2018 Share Posted March 1, 2018 Yes. As I peruse more in the help section, it states I must upgrade to Chief. Therefore, the help is inaccurate for Home Designer Pro. Thanks for responding so quickly. Link to comment Share on other sites More sharing options...
HomeProNoel Posted March 25, 2018 Share Posted March 25, 2018 Hi, I'm a new HomePro 2018 user. I'm trying to understand the responses to the original question as I'm having issues with saved layouts. The issue is that in order to create different layouts from one floor I need to create a layout then alter the dimensions, for example, for another layout type, such as electrical or reflected ceiling plan. When I open the first layout it does not show the dimensions and layer states that I saved for this layout. Is there a way of preventing these automatic changes? Link to comment Share on other sites More sharing options...
