Halcyon Posted March 27, 2016 Share Posted March 27, 2016 I'm at the stage now of starting to do my working drawings (layouts). The standard here is to express all dimensions in millimeters, but round them to the nearest 10mm. ie. 7774mm would be 7770mm. I cannot find a way to do this in my HD pro 2016. I could of course express dimensions in centimeters, but I am then not using the standard and can see a trady in a hurry cutting something to a tenth of it's length. Can this type of rounding be done in HD Pro 2016? In my state of Victoria only registered designers (and architects of course) can do plans for housing, but I think I can work around this and would like to get things close to right. Strange to say that one can build your own house, but not design it! I'm happy to post the plans,but think that maybe there is no need for this enquiry. Thanks. Pat Link to comment Share on other sites More sharing options...
English Posted March 27, 2016 Share Posted March 27, 2016 Don't know about metric but there is an option in Imperial to have the smallest dimension at 1". Have you tried to do that in preferences?Alan Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 27, 2016 Share Posted March 27, 2016 Edit - Default Settings - Dimensions - Format -Smallest Fraction in tenths or you can set how many decimal places to use. In that dialog you can also choose the Unit to use (mm, cm or m) DJP Link to comment Share on other sites More sharing options...
Halcyon Posted March 27, 2016 Author Share Posted March 27, 2016 Thanks for the replies English and David. I had looked at both these options, but they seem to go the opposite way to what I want. I think there is no way to do it in Pro, but will put it to Support and see what they say. Link to comment Share on other sites More sharing options...
Solution Halcyon Posted March 28, 2016 Author Solution Share Posted March 28, 2016 I contacted Support, and as suspected, there is no way to round the dimensions in the way I wanted. Perhaps a feature to add for future editions. Link to comment Share on other sites More sharing options...
solver Posted March 28, 2016 Share Posted March 28, 2016 Since you are doing the drawings, why not make the actual dimensions equal to the rounded dimension? 1 Link to comment Share on other sites More sharing options...
LawB10 Posted March 28, 2016 Share Posted March 28, 2016 When you click on a wall within a room, the dimensions line comes up, you click on that and make your changes. Link to comment Share on other sites More sharing options...
Halcyon Posted March 29, 2016 Author Share Posted March 29, 2016 Law & Eric. I have finished the drawings and have now started on the layouts and don't particularly want to start again ( for probably the sixth time). My fear (not unreasonable I think) is that once I start making small changes to wall lengths, all sorts of gremlins will enter the scene. Rounding to the nearest 10mm will make some walls longer and some shorter and my hard found experience is that the program does not like inconsistent wall lengths. At this stage my workaround will be to express the dimensions in cm's and then put a zero on the end of the number using the text function. A bit of work I know, but easier than fooling around changing wall lengths. A hint to the software writers: it shouldn't take much work to make this happen. Pat Link to comment Share on other sites More sharing options...
