heyseano Posted February 8, 2016 Share Posted February 8, 2016 Djp if you are active today I watched one of you YouTube tutorials on carports, it was the double stand alone carport. I am doing a standard house design with hipped roof. Off the side of t he house will be an attached single carport with near flat roof. If I create it as a porch it creates a hipped roof to match the house. If I change the roof pitch to 0 it makes the entire house with a flat roof. I thought maybe creating a slab for the floor and roof and some millwork as posts. The knowledge base also mentioned invisible walls but this doesn't fix the flat roof scenario Ideas ? Thanking you Sean Link to comment Share on other sites More sharing options...
Solution LawB10 Posted February 8, 2016 Solution Share Posted February 8, 2016 Go to the Library and take a peek at Exteriors>Structures If that's not what you want try this: Lower the ceiling height for the Carport, click each wall (3) and lower the pitch to 1/4" Link to comment Share on other sites More sharing options...
solver Posted February 8, 2016 Share Posted February 8, 2016 Set the pitch for the house in the build roof dialog, then set the pitch for the carport in one of its walls. Pitch set via a wall will override the default pitch. With Pro, you have the ability to draw manual roof planes too. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 8, 2016 Share Posted February 8, 2016 The point of auto roof generation, especially in Pro is to take what it produces and then MANUALLY edit the results to precisely what you want. Just take the next steps and learn manual roof editing. DJP 1 Link to comment Share on other sites More sharing options...
heyseano Posted February 9, 2016 Author Share Posted February 9, 2016 Thanks gents, will incorporate all 3 pieces of input. Thanks again Sean Link to comment Share on other sites More sharing options...
