Dentil Molding
English
Go to solution Solved by English,
I need some help with dentil molding.  I downloaded a file from 3D Warehouse and when I place it in my plan it is showing as a front view -- see screen shot.  In elevation view it's obviously not displaying correctly.  I can't seem to find a way to rotate it so that it displays okay in elevation.
Thanks
Alan
David
I downloaded SketchUp and rotated it but when I try to import it, it says it was created in an incompatible software version.  Do I have to purchase SketchUp Pro?
Thanks
Alan
No,  When you 'save as' in Skecthup you have to select which version ie: 2015, 2014 etc: Use the drop down list.
Any version you "save as" will work in HD
