Plainwacky Posted February 25, 2024 Share Posted February 25, 2024 What should the back overhang be set at on base and wall cabinets? Link to comment Share on other sites More sharing options...
y-g-m-n Posted February 26, 2024 Share Posted February 26, 2024 I Set them at 0 since I have the cabinets up against the wall and there is no room for an overhang. IF the back is exposed and out in open it would depend. but 1" is pretty much the standard overhang around where live. Now is there seating? like an island or peninsula? Then knee space rules dictate how much it should be and that is governed by height. See this - and peeps need to read it and follow it else you can get a goofy kitchen you end up hating: Basically, a free version of important rules to follow from Better Homes and Garden: Fundamental Kitchen Design Guidelines to Know Before You Remodel (bhg.com) And then the rule body National Kitchen & Bath Association: NKBA Link to comment Share on other sites More sharing options...
Plainwacky Posted February 28, 2024 Author Share Posted February 28, 2024 Hi...the back of my kitchen cabinets are against the wall. I think the default is set at 1" away from the wall and I was wondering why. Shouldn't the cabinets be right up against what wall and screw into the studs?? Link to comment Share on other sites More sharing options...
Rookie65 Posted February 28, 2024 Share Posted February 28, 2024 Yes. I think the 1" OH is there in case they are going to be used for an island. That way the OH will show, and then people won't have to add it. If you look at your plan when you draw it, once the cabinet is against a wall, the OH disappears anyway and becomes a moot point. Link to comment Share on other sites More sharing options...
Plainwacky Posted March 1, 2024 Author Share Posted March 1, 2024 When I butt my cabinets against the wall, I'm not seeing the 1" OH on the back going away. Link to comment Share on other sites More sharing options...
Rookie65 Posted March 1, 2024 Share Posted March 1, 2024 Where are you seeing it, the cabinets default setting? Or in the plan cutting into the wall? Link to comment Share on other sites More sharing options...
solver Posted March 1, 2024 Share Posted March 1, 2024 11 hours ago, Plainwacky said: When I butt my cabinets against the wall, I'm not seeing the 1" OH on the back going away. Use a Glass House view to look at the back of the cabinet. And why are you asking? Are you seeing a problem? Link to comment Share on other sites More sharing options...
Plainwacky Posted March 7, 2024 Author Share Posted March 7, 2024 I'm not seeing a problem....I was just curious as to why there is a 1" OH on the back. Didn't know if there was a reason for this. As I mentioned, I would think there would be no OH so that the cabinets would be right up against the sheetrock and screwed into the studs. Link to comment Share on other sites More sharing options...
y-g-m-n Posted March 7, 2024 Share Posted March 7, 2024 but if against the wall then it does not overhange. just like it does not overhang on the side when 2 or more cabinets screwed together. Only overhangs when it can into open space. Link to comment Share on other sites More sharing options...
