BoDay1 Posted July 10, 2023 Share Posted July 10, 2023 This seems like it should be so easy but it is a struggle. I'm bringing an interior wall to an exterior wall right at a corner. Of course the walls are different thicknesses. It will not flush-out as I need it to. Also, if I run a half-wall off that same area the programs strips the drywall off the wall surface above the half-wall. what am I doing wrong? Link to comment Share on other sites More sharing options...
Garybills Posted July 10, 2023 Share Posted July 10, 2023 In example 2 and 3 the interior of the walls are not in line. Example 1, I replicated you issue when I used a half wall which marks it as a railing. I unchecked railing which makes it a full height wall, but then selected the top of the wall in camera view and pulled it down which corrected the missing drywall. Link to comment Share on other sites More sharing options...
y-g-m-n Posted July 11, 2023 Share Posted July 11, 2023 when you align walls the STUDS need to align aka framing. aka main layer. . Link to comment Share on other sites More sharing options...
BoDay1 Posted July 11, 2023 Author Share Posted July 11, 2023 Thanks Y-g-m-n, But then what do you do when you have a 2x4 interior wall meeting a 2x6 exterior wall? If the framing lines-up centered then I can't get the surfaces right... but there must be some way to address this very common situation in building... Bo Link to comment Share on other sites More sharing options...
BoDay1 Posted July 11, 2023 Author Share Posted July 11, 2023 I managed to get the walls to line up simply by holding the ctrl key while moving it with the mouse. But the drywall is still removed even when I unselect the railing feature. I've tried drawing the wall as a regular interior wall and then just pulling it down in 3D but it still removes the drywall. Link to comment Share on other sites More sharing options...
Rookie65 Posted July 11, 2023 Share Posted July 11, 2023 Try going to the "structure" tab of one of the adjoining walls and select to continue the wall from the start or the end. Tough to tell from the picture if the wall running vertically is actually aligned. Much better to draw it as a half wall, rather than get in the habit of dragging walls down. Link to comment Share on other sites More sharing options...
solver Posted July 11, 2023 Share Posted July 11, 2023 For this type of question, someone really needs the plan file to work with, and to understand exactly where the wall should locate. Link to comment Share on other sites More sharing options...
