MississippiMims Posted October 19, 2022 Share Posted October 19, 2022 Anybody know how to make an invisible wall that wont show up in the floorplan? I cant get rid of the outline of the wall and this has been confusing for some framers. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 19, 2022 Share Posted October 19, 2022 Once you are through creating invisible walls, open "Display Options" while in your plan view and uncheck (Turn off) the "Walls, Invisible" layer. Then they will still be there but no longer visible in plan views until or unless you manually turn that layer back on. DJP Link to comment Share on other sites More sharing options...
MississippiMims Posted October 19, 2022 Author Share Posted October 19, 2022 I had tried changing the fill in the wall options. The only problem with turning off the invisible walls layer in the Display Options is I still need the invisible walls for the porches to show up in the floorplan. I'm trying to isolate this particular invisible wall. Link to comment Share on other sites More sharing options...
Rookie65 Posted October 19, 2022 Share Posted October 19, 2022 Change the line style to "blank" in the default for the walls you don't want to show. When you open up the line styles, you will see one row that has nothing in it. Link to comment Share on other sites More sharing options...
solver Posted October 19, 2022 Share Posted October 19, 2022 14 minutes ago, MississippiMims said: The only problem with turning off the invisible walls layer in the Display Options is I still need the invisible walls for the porches to show up in the floorplan. I'm trying to isolate this particular invisible wall. It's really helpful to include info like this when you ask a question. I'd use a mask to cover the wall. Link to comment Share on other sites More sharing options...
solver Posted October 19, 2022 Share Posted October 19, 2022 6 minutes ago, Rookie65 said: Change the line style to "blank" in the default for the walls you don't want to show. When you open up the line styles, you will see one row that has nothing in it. I believe the dashed lines are controlled by the Layer. Even if you set a wall to have all blank lines, you still get the dashed lines when you make it invisible. In Chief, you can place the wall on a unique layer and control the lines, setting them to blank and the wall will not show. Link to comment Share on other sites More sharing options...
MississippiMims Posted October 19, 2022 Author Share Posted October 19, 2022 Keith, were you able to make the "blank" line style work? When I tried it would not go away. Eric, would you place a mask on the layout sheet or is this something that's available for the plan? Link to comment Share on other sites More sharing options...
solver Posted October 19, 2022 Share Posted October 19, 2022 9 minutes ago, MississippiMims said: would you place a mask on the layout sheet or is this something that's available for the plan Should work either place. Link to comment Share on other sites More sharing options...
Rookie65 Posted October 19, 2022 Share Posted October 19, 2022 No, I didn't try it, and Eric is correct. I would do the mask on the plan sheet using a polyline and making the lines blank and the infill white. When it's put on the layout, it may creat a blank area for any other pages put over that area. Invisible walls used to work nicely when they were just a single line. Link to comment Share on other sites More sharing options...
MississippiMims Posted October 19, 2022 Author Share Posted October 19, 2022 Thanks Eric. Does Chief Architect have more layer control so that I can have text on different layers as well as CAD lines on different layers? Link to comment Share on other sites More sharing options...
MississippiMims Posted October 19, 2022 Author Share Posted October 19, 2022 Thanks for the try Keith. Link to comment Share on other sites More sharing options...
Rookie65 Posted October 19, 2022 Share Posted October 19, 2022 Sure. The polyline does work with the solid white infill Link to comment Share on other sites More sharing options...
