ChiefJeet Posted July 7, 2020 Share Posted July 7, 2020 I have taken a normal Cross Section which shows roof framing but also the other items in the background. To avoid seeing items in the background, I took a backclipped section but this do not show any roof framing. Is there a work around this? StaffordRd577 Store.plan 1 Link to comment Share on other sites More sharing options...
solver Posted July 7, 2020 Share Posted July 7, 2020 Make sure you are not clipping framing. When things do not display as expected, start with Layer Display Options. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 7, 2020 Share Posted July 7, 2020 The "Framing " layer is OFF by default in cross section cameras you must manually check that layer ON in order to see framing (each camera type and all plan views have each their own "Display Options" so like Eric said open display options for the view you are in to see what is ON or OFF. DJP Link to comment Share on other sites More sharing options...
