ICONDEV Posted February 25, 2020 Share Posted February 25, 2020 How can extend the eve of just one end of a shed roof? I'm only wanting to increase the uppermost eve of my shed roof for exterior accent lighting. 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted February 25, 2020 Share Posted February 25, 2020 Try clicking on it and dragging it to the dimension you need. Link to comment Share on other sites More sharing options...
ICONDEV Posted February 25, 2020 Author Share Posted February 25, 2020 I thought that was how I had done this in the past, but it will not let me select just the roof plane only to do so. Link to comment Share on other sites More sharing options...
solver Posted February 25, 2020 Share Posted February 25, 2020 Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 25, 2020 Share Posted February 25, 2020 If you have turned OFF "auto build roof" (as per your last post), then why would you think that your overhang should rebuild? Link to comment Share on other sites More sharing options...
ICONDEV Posted February 25, 2020 Author Share Posted February 25, 2020 if it's above the 1st level would I go to attic level to active this? I'm only wanting to extend the 2 upper rooflines in the picture Link to comment Share on other sites More sharing options...
ICONDEV Posted February 25, 2020 Author Share Posted February 25, 2020 12 minutes ago, Jo_Ann said: If you have turned OFF "auto build roof" (as per your last post), then why would you think that your overhang should rebuild? I don't expect it to. I just want to know how to manually increase the eve/overhang on the right two rooms w/ high shed roofs, past what my defaults are set to. Link to comment Share on other sites More sharing options...
solver Posted February 25, 2020 Share Posted February 25, 2020 15 minutes ago, ICONDEV said: I just want to know how to manually increase the eve/overhang on the right two rooms w/ high shed roofs, past what my defaults are set to. You can't. You only have the ability to auto build roofs. You would need to upgrade to Pro to get manual roofs. Link to comment Share on other sites More sharing options...
ICONDEV Posted February 26, 2020 Author Share Posted February 26, 2020 22 hours ago, solver said: You can't. You only have the ability to auto build roofs. You would need to upgrade to Pro to get manual roofs. So this means that with my current version, I have to increase the overhang on the entire wall and cannot apply to specific walls, correct sir? Random idea, would placing wall-breaks along that back wall allow me to select my specific wall(s) and adjust the overhang?? Thanks as always! Link to comment Share on other sites More sharing options...
