447Debbie Posted October 5, 2019 Share Posted October 5, 2019 I'm trying to create a wall cabinet with the default cabinet door to be CLEARCOAT walnut. You can see I have the default set at CLEARCOAT walnut. However, when I go to the cabinet and tell it to use the default, it uses some other walnut (you'll have to trust me that these are two totally different walnuts). On the picture I have attached, I selected CLEARCOAT walnut so that you see what it looks like, then I checked the 'Use Default' box. Once I check the 'Use default' box, it reverts to the other generic walnut. What am I doing wrong? Link to comment Share on other sites More sharing options...
Rookie65 Posted October 5, 2019 Share Posted October 5, 2019 What happens if you change the view from "physically based" to 'standard?" Link to comment Share on other sites More sharing options...
447Debbie Posted October 5, 2019 Author Share Posted October 5, 2019 I'm not sure I know what you mean by "physically based" to "standard". I've never run across those terms. I have the same problem defining defaults with the crown molding. The crown molding default in the room seems to override the crown molding material default on the cabinets. (They are different). I wonder if there is a cabinet door default being define elsewhere that overrides the cabinet door on the cabinet. Link to comment Share on other sites More sharing options...
Rookie65 Posted October 5, 2019 Share Posted October 5, 2019 In your picture on the right, above the plain walnut comment, there is a little picture of a house w/a yellow roof. look there and change it from "physically based" to "standard." It will change how the material looks and it may be what you want. Link to comment Share on other sites More sharing options...
solver Posted October 5, 2019 Share Posted October 5, 2019 Link to comment Share on other sites More sharing options...
solver Posted October 5, 2019 Share Posted October 5, 2019 Always look at things in the plan -- that's the only place they need to look correct. Link to comment Share on other sites More sharing options...
447Debbie Posted October 5, 2019 Author Share Posted October 5, 2019 Plan view is showing the plain walnut when I use defaults even though the default is CLEARCOAT walnut. Draw fronts on the base cabinets have the same problem. Crown on the cabinet can have the cabinet default set as CLEARCOAT walnut, but when I choose default for the crown on the individual cabinet, it uses white, which is what I use for the wall crown molding. I think this is a bug. Link to comment Share on other sites More sharing options...
solver Posted October 5, 2019 Share Posted October 5, 2019 Where does clearcoat walnut come from? I don't see it in the standard catalogs. Link to comment Share on other sites More sharing options...
447Debbie Posted October 5, 2019 Author Share Posted October 5, 2019 I found the problem with drawer fronts and doors. Those defaults had to be set under Default Settings Materials Edit Cabinet Door / Drawer I was setting them under Default Settings Cabinets Base or Wall or whatever Materials Then Drawer/Door Link to comment Share on other sites More sharing options...
447Debbie Posted October 5, 2019 Author Share Posted October 5, 2019 1 minute ago, solver said: Where does clearcoat walnut come from? I don't see it in the standard catalogs. It came from Barker Cabinets so it was an outside source. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 5, 2019 Share Posted October 5, 2019 Home Designer and Chief Architect software is basically a robotic assistant BUT you must tell it what to do, otherwise, it just keeps following preset "Defaults" unless you manually change those default material settings yourself. There are several places to set the default materials for Cabinets: 1. In "Edit - Default Settings - Cabinets" there are default setting for each cabinet type (Base, Wall and Full Height) 2. In "Edit - Default Settings - Materials" there are separate settings for Cabinet, Cabinet Door/Drawer The software is not programmed to do this for you, you must manually address the settings above per object to make sure the software then does "automatically" what you wish. DJP Link to comment Share on other sites More sharing options...
