Remove base molding from shower HDP2020
TreborSinad
Hello,
How do I remove the base molding from a shower in Home Designer Pro 2020. There is a article "Removing Moldings from a Single Wall" in the knowledge base but it says to "Make Room Molding Polyline roommolding.png?1550099619 "  I don't find that function in HDP2020. Am I missing the function or is there another way to remove the base boards? BTW, the other side of the wall needs base boards, and the rest of the restroom needs base boards.
Thanks again! :)
Hello Solver,
Thanks for the reply. The Room Specification dialog does not allow me to remove a specific section of baseboard without removing all the baseboard in the room. Attached is another example. There baseboard in front of the cat door. How can i cut into the base board without removing the bottom of the baseboard or removing the baseboard from the entire room? Is there a way to make the baseboard a polyline?
Thanks again,
Trebor
