rfcomm2k Posted November 14, 2014 Share Posted November 14, 2014 In the attached picture there are two views of the toekick area of some cabinets. If the cabinet is allowed to snap itself to the adjoining wall, the baseboard trim which should continue up to the toekick is truncated at the depth of the entire cabinet. If I drag the cabinet to be short of the adjoining wall the trim continues as it should, but then the cabinet is not the correct size. Any suggestions? Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 14, 2014 Share Posted November 14, 2014 I could not duplicate the results you are getting on my copy of Pro, can you post a copy of the plan here please? DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted November 15, 2014 Share Posted November 15, 2014 This is a long-time "bug" which has never been 100% fully fixed , seems to happen sometimes and not others . You may find posts on the Legacy Forum about it too but not sure if there is a definitive "fix" M. Link to comment Share on other sites More sharing options...
rfcomm2k Posted November 16, 2014 Author Share Posted November 16, 2014 Here is the plan Link to comment Share on other sites More sharing options...
solver Posted November 16, 2014 Share Posted November 16, 2014 I get these type of problems with almost every plan. Sometimes they go away when something seemingly unrelated is changed. Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 16, 2014 Share Posted November 16, 2014 Use a piece of soffit, same height and depth as the molding, and add molding to it (same height and depth). Slide it into place. Problem all gone. Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted November 16, 2014 Solution Share Posted November 16, 2014 If you will uncheck "Flat Sides" check box in the "Toe Kick" catagory on the "Cabnet Specification Dialog" then that will allow the base mold to fill those gaps (I downloaded your plan and that is what I found to work). DJP Link to comment Share on other sites More sharing options...
rfcomm2k Posted November 17, 2014 Author Share Posted November 17, 2014 Great catch David, thanx! Link to comment Share on other sites More sharing options...
