bddemers Posted October 17, 2018 Share Posted October 17, 2018 2 Questions: 1. Building a simple detached, covered patio. I want to design the trusses to look like I want. I am trying to place the trusses and have the roof planes built and in place. I have posts and beams set up. I am getting this error....Could not create a roof truss at this location because no roof planes were found. Would you like to create a general framing member instead? I even tried to build regular exterior walls and place the trusses and still get the same error. What am I doing wrong? 2. I have a detached Garage with a second story. When I selected the Garage and then added the second floor, it added a second floor to my house. How do I stop that from happening? Thanks for any help. Schluersburg PLAN D OCT '18.plan Link to comment Share on other sites More sharing options...
solver Posted October 17, 2018 Share Posted October 17, 2018 I bet the Help system and Knowledge Base have info on trusses. 22 minutes ago, bddemers said: I have a detached Garage with a second story. When I selected the Garage and then added the second floor, it added a second floor to my house. How do I stop that from happening? Thanks for any help. You don't. Just delete the walls you don't want. Link to comment Share on other sites More sharing options...
bddemers Posted October 17, 2018 Author Share Posted October 17, 2018 I tried the Help system and Knowledge Base already. No help. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 17, 2018 Share Posted October 17, 2018 In order to manually build trusses, using the manual Truss tool you MUST have a "flat ceiling" in place by way of the room specification dialog (no ceiling equals no trusses possible). When the ceiling and roofs are in place only then can you, using the manual truss tool, create and place roof trusses. The truss tool is pre-programmed to use the void between the ceiling and the roof planes to use to fill that void with trusses (it will not work if there is no flat ceiling). If you do not need or want the roof rake (end) walls, then mark them "Invisible" and in Display Options for camera views turn ON framing, otherwise it is by Default, not visible unless you manually turn its layers on. DJP Link to comment Share on other sites More sharing options...
solver Posted October 17, 2018 Share Posted October 17, 2018 Trusses need a ceiling -- does not need to be flat, and if there is a ceiling somewhere in the room, even with Ceiling Over This Room unchecked, they may be drawn, and will fill in like there is a ceiling. Link to comment Share on other sites More sharing options...
Jo_Ann Posted October 17, 2018 Share Posted October 17, 2018 Link to comment Share on other sites More sharing options...
bddemers Posted October 17, 2018 Author Share Posted October 17, 2018 Thanks for all the replies. All helpful. I'm making progress! Link to comment Share on other sites More sharing options...
solver Posted October 18, 2018 Share Posted October 18, 2018 Link to comment Share on other sites More sharing options...
