4ndrew
Glass wall up against framed wall?
I'm trying to build a glass shower enclosure and have looked through a bunch of posts.
I can't find a way to have a continuous run of walls in which there is a transition from a standard framed wall to a glass wall without the end of the framed wall being exposed... any help appreciated!
Red line points to a Room Divider wall.
Pull the glass wall back so it does not automatically connect. Draw the Room Divider, then snap the glass back.
Draw 2 room dividers around the glass wall forming a room. Turn off the molding in this room.
Move the walls 1/64" away from the glass.
Thanks guys!
Both look great. I'm a bit.. ah... well, call it what you like, but a 1/64" gap drives me crazy :)
cheers
Andrew
Ok - tried these out... does Home Designer Pro allow selective molding in a room (just some walls) ?
No. That's why the trick with the invisible walls and 1/64" spacing. You are creating a tiny room with no moldings.
