Second floor overhang, Possible?
Lynkage
Hello all, I am new and researching HDP to see if I can draw my design with the software. So far I am really impressed with it. While I do not totally understand all items and processes to achive what I want, the videos and training are very good and I feel that most of my questions can be answered buy just watching and reading.
I have not however been able to find an answer as to how to make a second floor overhang a first floor with post and beam construction. Is this possible? Other methods?
Thanks in advance for any assistance. :)
I'm sorry but I only have a quick side view.
I am building a room over an attached garage. The Garage is not built yet but the foundation/monolithic is already poured and I would like another 4' of space in the room above so the construction will need to extend out over one wall with glue-lams and posts at the end of the beams. I would probably just use steel connectors and bolts for the support. The Garage is 32 wide and 30 deep and I want the room to overhang going front to back so I will achieve a 34' deep room above the 30' deep garage.
The house is really a 1.5 story with a 12/12 pitch roof going width wise over the garage and the dormers will be front and back (depth of the garage)
The extension is 28' wide and extends out 4' + a 18" roof overhang. Second floor is an 8' knee wall and gable dormer with an approximate slop of 4-5/12. House height (as well as the attached garage) is 25' 2" garage floor to peak. The overhang is on the left of the drawing.
Ignore the door in the drawing. That will end up inside the garage.
Thanks for trying to help me! ;)
I would say it's entirely possible to do what you're asking in the software, it's a matter of how.  The software probably won't do it automatically, you'll have to draw in beams and posts using either "soffits" in the cabinet tools or "boxes" in the library to represent these items.  It takes a little time to place them correctly and you may have to use multiple shapes to get the decorative cuts you're after but you will end up with a pretty accurate representation of your plan.  Work with your engineer to get the dimensions for the beams and draw them in manually after you've created the structure you're after.
Hope this helps!
-John
No software in the Universe draws or creates anything, rather it is you who is the only important factor in terms of outcomes, not what software you use. In capable, certain hands, this software can assist you to the goal of a digital, relationally correct copy of your home AFTER you have self-disciplined yourself to learn how to use it and its tools.
Best of success~
Hope this helps!
-John
That's pretty slick John! To pull the floor out over the doors is the part that I am curious about doing, however thanks for pointing out the soffit and/or box method for the details on the beams! That was extremely helpful! :)
That's just what you do. Grab the wall with the mouse and move it, or select it and move it with dimensions, or use Transform/Replicate.
That's the easiest part of what you want to do.
Best of success~
Thanks for your reply DJP.
I do understand what you are saying, I am however really impressed with the tools provided by Chief  (videos, type etc.) that can help teach me to use the software. So many software options are either very incomplete in this area or require so many plugins to get what I am after, it becomes difficult to search for the proper methods to accomplish the end result.
I am trying to find a piece of software that I can stick with and get more proficient with over time. HDP looks like it has most everything I could want. I am about 2 weeks into the trial and I am pretty impressed with what I have been able to do so far.
Thanks for your time.
Perfect!
Thanks Solver!! :D
