rybolt47 Posted January 19, 2018 Share Posted January 19, 2018 I am drawing a 20ft x 20 ft pyramid cabin with Home Designer 2012. The roof pitch is 52 degrees. I want to have an exterior door entry way that sets in about 7 ft from outer exterior of pyramid with no roof or ceiling above. Do I draw a interior wall for the door or an exterior wall? I'm having a problem drawing this with the door entrance being exposed. Thanks for your help. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 19, 2018 Share Posted January 19, 2018 I do not believe you will be able to do as you intend using 2012 unless you have Home Designer Pro. No Chief Architect or Home Designer software can do slanted walls (you have to use roof planes as "walls" and roof planes cannot hold doors and windows, only skylights). You might fare better using Sketch Up for such an exotic design. DJP Link to comment Share on other sites More sharing options...
rybolt47 Posted January 19, 2018 Author Share Posted January 19, 2018 Thanks for your response .I do have Home Designer Pro I tried drawing a foundation set in 7 ft. with 6 inch walls and then designated roof angle as 52 degrees. I designated the inset area as a porch with no roof or ceiling but still had no luck with a door entry way. Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 19, 2018 Share Posted January 19, 2018 Are you trying to get one of these results? Link to comment Share on other sites More sharing options...
rybolt47 Posted January 19, 2018 Author Share Posted January 19, 2018 Thanks Jo Ann. The shorter Pyramid is what I'm trying to achieve. How did you do that to make the door entryway open? Link to comment Share on other sites More sharing options...
solver Posted January 19, 2018 Share Posted January 19, 2018 Are you comfortable with the manual roof tools? This is a very simple roof to build using them. Link to comment Share on other sites More sharing options...
rybolt47 Posted January 19, 2018 Author Share Posted January 19, 2018 Is that the way JoAnn did the example shown? If so I will read into the knowledge base on drawing manual roofs? My concern was how to get the door/entry way to be open and cut through the roof above. Link to comment Share on other sites More sharing options...
solver Posted January 19, 2018 Share Posted January 19, 2018 Providing an image of your model helps. Often it's a simple setting change. This keeps others from needing to supply step by step, start to finish instructions. I've made the outer room ceiling 0". The outside walls flanking the entry are set to Gable. Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 19, 2018 Share Posted January 19, 2018 This has been done with 'auto build roof'. It's pretty much like Eric explained, but looking at the plan is easier that trying to explain it. Pyramid type roof.plan Link to comment Share on other sites More sharing options...
rybolt47 Posted January 19, 2018 Author Share Posted January 19, 2018 Thank you both for your help. It is very much appreciated. Link to comment Share on other sites More sharing options...
