SeabeeMike Posted January 18, 2018 Share Posted January 18, 2018 Using Home Designer Architectural 2018 This cannot be this difficult I'm trying to install a pair of exterior french doors with no jamb between them. I can get a single door with no problem. If I add a second door, I cannot merge the two to one unit with no hamb. HELP!!! Link to comment Share on other sites More sharing options...
solver Posted January 18, 2018 Share Posted January 18, 2018 Change Minimum Separation to 0. Link to comment Share on other sites More sharing options...
SeabeeMike Posted January 18, 2018 Author Share Posted January 18, 2018 Hi Eric - Thanks but that shows a pair of windows. Presume I just change the height and zero them to the floor and they're then considered "doors" rather than windows? I thought there may be a way to use the door rather than window. Link to comment Share on other sites More sharing options...
solver Posted January 18, 2018 Share Posted January 18, 2018 The setting is located in the Window Defaults, but it works for windows and doors. Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 18, 2018 Share Posted January 18, 2018 Widen the single door...it becomes two doors. Link to comment Share on other sites More sharing options...
solver Posted January 18, 2018 Share Posted January 18, 2018 14 minutes ago, Jo_Ann said: Widen the single door...it becomes two doors. I bet you are correct. I was thinking this. Link to comment Share on other sites More sharing options...
LawB10 Posted January 18, 2018 Share Posted January 18, 2018 Minimum width 48" or open the specification box, click options >double doors only. Link to comment Share on other sites More sharing options...
SeabeeMike Posted January 19, 2018 Author Share Posted January 19, 2018 Thanks all - Jo_Ann's tip was the simple fix I knew had to exist! Link to comment Share on other sites More sharing options...
