Trueburton Posted December 23, 2017 Share Posted December 23, 2017 I am trying to draw a detailed cross section with labels and appropriate call outs for materials for this new home plan I am working on. I did a back clipped cross section to get started. I want to be able to add/edit items to create a fully detailed cross section without changing anything in the plan drawings. I'd like to crop the image of my back clip and then just edit it from there but I can't figure out how to do it. How is everyone else doing this? Link to comment Share on other sites More sharing options...
Rookie65 Posted December 23, 2017 Share Posted December 23, 2017 See if this link will help. https://www.homedesignersoftware.com/support/article/KB-00439/creating-a-cross-section-detail.html?utm_content=&utm_source=VerticalResponse&utm_medium=Email&utm_term=Learn how&utm_campaign=Home Designer Software News Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 23, 2017 Share Posted December 23, 2017 I guess you could export the cross section as a .dxf file (If that is what you want to do?) and then in that form you could then work on it as you would in AutoCAD where all objects visible are merely lines. I use the method described in the KB article that Rookie65 posted, that is your best solution within HD Pro. DJP Link to comment Share on other sites More sharing options...
Trueburton Posted December 24, 2017 Author Share Posted December 24, 2017 18 hours ago, Rookie65 said: See if this link will help. https://www.homedesignersoftware.com/support/article/KB-00439/creating-a-cross-section-detail.html?utm_content=&utm_source=VerticalResponse&utm_medium=Email&utm_term=Learn how&utm_campaign=Home Designer Software News I had done a few searches before asking the question but did not find this article. This is exactly what I needed. Thanks! Link to comment Share on other sites More sharing options...
Trueburton Posted December 25, 2017 Author Share Posted December 25, 2017 I am not getting the framing shown in these cross sections I clicked on auto build framing but its not showing up? Am I doing something wrong? Link to comment Share on other sites More sharing options...
solver Posted December 25, 2017 Share Posted December 25, 2017 Each view has its own layer set. Framing is not on by default in the Cross Section layer set, so you need to turn it on. I believe you have an All On layer set. It's a quick way to see all layers on in whatever view you are in. Link to comment Share on other sites More sharing options...
Trueburton Posted December 25, 2017 Author Share Posted December 25, 2017 I can get it to show floor framing but not the top and bottom plates of the walls. I checked all the boxes for framing sill plates Link to comment Share on other sites More sharing options...
solver Posted December 25, 2017 Share Posted December 25, 2017 Everything shows in a framing overview? Are you using a Back Clipped cross section? Link to comment Share on other sites More sharing options...
Trueburton Posted December 25, 2017 Author Share Posted December 25, 2017 yes back clipped cross section. Also I cant get the "save active camera" to do anything. I click on the button and nothing happens Link to comment Share on other sites More sharing options...
solver Posted December 25, 2017 Share Posted December 25, 2017 5 minutes ago, Trueburton said: Also I cant get the "save active camera" to do anything. I click on the button and nothing happens It just saves the camera -- does not do anything visually. 5 minutes ago, Trueburton said: yes back clipped cross section. In plan view, turn on wall framing. Make sure the camera is taking in the wall framing and is not between studs. Link to comment Share on other sites More sharing options...
Trueburton Posted December 25, 2017 Author Share Posted December 25, 2017 ok so i got it to show the wall framing members. But can I save this image so I can edit it and add labels without affecting the plan file? Link to comment Share on other sites More sharing options...
solver Posted December 25, 2017 Share Posted December 25, 2017 Draw a new plan. Take a cross section. Make some mods, save camera. Save the plan. Close and reopen. Double click the saved camera and see what is saved. Link to comment Share on other sites More sharing options...
Trueburton Posted December 25, 2017 Author Share Posted December 25, 2017 sorry, I geuss I'm not understanding where the saved camera goes after it is saved? Does it just save it within the plan file? It doesnt create a new file to save Link to comment Share on other sites More sharing options...
solver Posted December 25, 2017 Share Posted December 25, 2017 Did you go through the steps in #11? When you reopen the plan, the saved camera will be there, unless it's layer is off. Link to comment Share on other sites More sharing options...
